Explorer overheating and boiling in reservoir | Ford Explorer - Ford Ranger Forums - Serious Explorations
Clay44
Thunder Bay On.
91 Explorer
Please can any one help me my coolant is boiling in the reservoir and the truck over heats to the L in normal thanks
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL Pumpkin Edition
Callsign
AB7FH
Check to see if your system holds pressure. If there are any leaks or if you have a bad radiator cap the system can't pressurize and that lowers your boiling point.
I had a leak in the side of my radiator where the plastic tank meets the core. It wasn't even enough of a leak to drip on the ground, it was just seeping out. Anyway, replacing my radiator fixed me up.
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
Callsign
AB7FH
I almost forgot. Welcome to the site:chug:
Clay44
Thunder Bay On.
91 Explorer
Thanks for the help I'll try that
ma96782
Vancouver, WA
'94 XLT, 4dr
My STOCK answer on over heating problems: (beside changing a radiator or water pump)
If you got the tools or access to the kit........pressure check the system.
___________________________________
T-stats can be checked w/ a thermometer and a pot of hot water………or just replace them……….they aren’t that expensive.
____________________________________
While running and with the engine off, make a visual check of the hoses for a hole, check for leaks at the connections. If it passed the pressure test, you should be OK. But, still check for a, "too soft" hose, which may collapse.
_____________________________________
Replace radiator cap........IF, you can't remember when it was last done........or if it's been more than a couple years since it was last changed. If it passed the pressure test, you should be OK.
Time for new anti-freeze………don’t forget to mix it right.
Fan Clutch...............when cold (engine off) try spinning the fan....it should spin freely or with very little resistance. If it won't spin.....replace.
When hot (engine off) try spinning the fan........in some cases it will feel like it's, "locked up," or it will be like there is syrup/glue holding it back. Tougher to spin, than when it was cold. If so, It's OK. If, it spins like a top.....replace.
The below elec. tests are the, "cheap test methods"........there are more sophisticated tests with values, that can be run.
Test for the dash thermo gauge................disconnect the wire from the temp sender unit.........KOEO...........ground that wire.........it will peg the gauge on the hot side............disconnect from ground and it will return.
Sender unit.........if you suspect it..........replace, replacement is cheap.
Aloha, Mark
