Solid axle up front on a BII is fairly simple to do, but not always cheap, especially when you get into shortening the axle, welding new mounts, rebuilding the R&P, U joints, wheel bearings, etc etc...
The cheapest easiest way to breathe new life into that BII is to purchase the entire donor vehicle. a 93-94 4.0L Explorer thats rolled with as low miles as you can find is the way to go...
You can swap everything from the Ex into the BII with most of it bolting right up, of course be prepared for long hours and lots of kicking yourself...
It took me 7 years to piece my truck together, 5 of those I spent diddlying around with stuff I should have just thrown away, like the 2.9L, cheap lift kits, etc...
But I like to take the long road with my truck apparently
Now she is really coming together, here is my setup:
-1988 BII Eddie Bauer 248K miles on Chasis
front suspension:
-Dana 35 TTB, custom built with 3" cut and turn, widened track width
6" Skyjacker coils
Skyjacker extended radius arms
4.10 R&P
ARB locker
Custom axle shaft
Warn hubs
James Duff axle pivot brackets
2" drop pitman arm
4" brake lines
Rancho 9000
custom sway bar with disco's
Rear:
1997 31 spline 8.8 disc brake, 4.10 R&P, factory L/s, rebuilt
converted to spring over, welded on spring pads for BII
4" Skyjacker leafs
2" tappered iron block
Rancho 9000
Custom driveshafts front and rear
Drivetrain:
1993 OHV 4.0L:
3 core super cooling aluminum radiator
11 blade super cooling Ford fan and clutch
A/C removed
180 thermo
KKM filter
Granatelli 70mm MAS
95 Ranger intake tube
BBK 66mm TB
JBA headers
Custom Y pipe
2.5" single exhaust with high flow cat, Flow Pro muffler
Taylor Spiro wires
Bosch PLat +4
CUSTOM 4.0L wiring harness
1993 A4LD auto (truck originally a 5 speed)
Custom rebuild, custom torque converter, modified valve body
BW 1354 touch drive T case
1984 BII 2wd floor shifter and bell crank assembly
Other:
1997 Eddie Bauer power leather buckets
1990 Eddie Bauer BII door panels, headliner, interior trim to match mocha seats
Custom dash and interior
AutoFAB front fenders
James Duff prerunner receiver bumpers front and rear
Superior chrome Startech 15x7.5" rims
Remington 33x12.5 Mud Brute's
Hella H4 headlights
PIAA 1500 driving lights
KC 5x7 on Yakima rack
Coming soon:
removable side windows
Custom rear hatch with removeable glass, re-enforced tire carrier
Roll bar/cage
Rocker protection
new/ custom paint (again)
Sunroof
Custom shock hoop and coil bucket
PS cooler
New OHV engine with lots of internal power adders
Possibly 3 speed C4 trans and eventually 35" tires
Here's some recent pics from Moab, oh and who says you need a solid axle to go off road? My TTB will make it, even with just 3wd
Dead Link Removed
