Lexingtonian
- February 2, 2017
- Lexington, KY
- 2016 Exp Sport w/401a
Just for reference, my 60k mile original fluid had:
Aluminum: 4
Iron: 262
Insoluble: 0.2
Lexingtonian's report showed higher levels @ 16k miles than mine did at 60K miles.
Seems like fluid results are all over the place.
To your knowledge was yours changed at all before 60k? Assuming not, but simply curious. My analysis results are encouraging to me because of the drop in iron by half. It tells me that my PTU has essentially stopped shedding (whatever was in it at 16,000 miles). Unfortunately the way these are designed, you only get about 2/3's of the oil out when draining. I get around 12 ounces and it holds 18 as I recall.
Hard to know why the metals are the way they are, but from the analysis reports I'm seeing, it's very normal for these units. Care to post your whole report for posterity? Thanks!
Fortunately for me I have ESP till 150,000 miles or 8 years. I'm not going to worry about it and will keep a 30-40K'ish change regimen based on the data I'm seeing.
