  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
Explorer SiriusXM Stuck "Acquiring Signal" (Intermittent) 2018 Models
Franklin Field Jr.
East Earl
2018 Explorer XLT
Well here we are in the “next few weeks” and “mid December” as some were told here and about to enter 2019 and NOTHING!!!???
TimmyB1957
Sarasota, FL
2018 Explorer Limited
OK, brand new member here with similar issue. Mine has a weird twist to it, though. Got our vehicle in late June, 2018. We are 9800 miles, currently and the car has exceeded almost all of our expectations. Yesterday, took it into Sarasota Ford for its first oil change, which we were notified by the vehicle itself that it needed to have. They gave me the complimentary car wash afterwards and I was on my way.
Last night, we went out to dinner and experienced the same satellite acquiring signal message as all the others. Having had satellite in my vehicles since 2003, I know what is "normal" and what is not; this was definitely NOT a normal situation for when signal would have been lost. I thought maybe the antenna had been messed up during the car wash so after arriving at the restaurant, I checked and sure enough, it was bent about 30 degrees from normal. I immediately called the dealer and he had me come in today and get a new one. (The satellite DID work as usual on the drive to the dealer, today.) He was not convinced that this new antenna was going to "fix" the issue, but he was replacing it simply because the other one was bent. (After reading this thread, I am strongly thinking that he was aware of the "acquiring signal" problem that others are having. It is a VERY large dealer and I'm sure that someone has been down this road with him before.) He simply screwed on the new antenna and we were on our way. FWIW, the "new" antenna is a very flexible, all rubber tube, not the twisted metal previously used. He said there had been quite a few of these damaged by car washes, so he was guessing Ford changed the style for that reason.
Either way, I will stay in touch with this thread with any changes or recurrences.
timmy
15Limited
TN
2018 Sport 4x4
timmy
Sounds like you are referring to the radio (am/fm) antenna, not the satellite antenna...the screw on antenna will not affect satellite reception.
TimmyB1957
Sarasota, FL
I'm aware of that. That's why I said it was a bit strange at the beginning. Not had this problem before the incident with the wash yesterday, and didn't have it at all today. Coincidence? Probably, but quite strange to say the least. We'll see if it recurs or not.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
I wonder if that 'new' AM/FM flexible type antenna may be the 'fix' to the issue? Why else would Ford suddenly change it? Less interference than from the twisted metal OEM one.:dunno:
TimmyB1957
Sarasota, FL
I'll leave that for the antenna experts to argue over. I'm just hoping I had one bad day of it and that was it! :)
15Limited
TN
2018 Sport 4x4
The 2019s use the same am/fm ‘twist’ antenna as the 2018s, so no change. It wouldn’t surprise me the service manager put on an aftermarket antenna that is car wash safe.
TimmyB1957
Sarasota, FL
Not likely. I was with him when he called his parts department and gave them the part number for my vehicle and when they told him they had one, he went straight over and picked it up.
15Limited
TN
2018 Sport 4x4
Hopefully it works for you and solves the issue...as a minimum you will have less issues going thru a wash, so that’s a win already :)
TimmyB1957
Sarasota, FL
Yep. I'm definitely glad I don't have to worry about that. Funny thing is, I got it washed regularly at a nice drive through wash a dozen times with no problem; first time at the dealer, and... :D
jmr061
Wisconsin
16 Edge
Pr-16 Exp Sport
As I figured they need to replace the antenna.
Contact your service dept and get yours fixed...
TECHNICAL SERVICE BULLETIN #18-2358
Sirius Satellite Radio With 4G TCU Modem - Loss Of Signal/Acquiring Signal Message Displayed - Built On Or Before 13-Nov-2018
Issue: Some 2018-2019 Explorer vehicles built on or before 13-Nov-2018 equipped with a 4G telematics control unit (TCU) modem may exhibit an Acquiring Signal message with a loss of satellite radio reception while driving in unobstructed areas.
TimmyB1957
Sarasota, FL
So, help a newbie out here, Jason. Is this saying that all dealers are now being told to replace the antenna or just that the problem exists?
Thanks.
t
jmr061
Wisconsin
16 Edge
Pr-16 Exp Sport
The fix is to replace the antenna. They will probably have to order it unless some larger dealers decide to stock it.
TimmyB1957
Sarasota, FL
OK, thanks. I am guessing by "replace the antenna", you/they are saying the entire component attached to the roof, not just the screw-on part of it. (?)
jmr061
Wisconsin
16 Edge
Pr-16 Exp Sport
Ford OASIS.
ExpSport2018
2018 Explorer Sport
Ford OASIS.
Thank you. I did get a note from a contact at Ford this morning saying they were trying to determine a distribution method, but didn't say what they would be distributing.
peterk9
Staff member
Moderator
Callsign
VE3
I believe that antenna they gave you is "the fix" as I thought.
jmr061
Wisconsin
16 Edge
Pr-16 Exp Sport
Its the entire antenna assembly. They have to pull trim inside and drop the rear of the headliner. Time is give as 1 hour for the repair.
kevinrossen
Lewisville, TX
2018 Explorer XLT
Joined the forum to jump in on the conversation. I've had the same issues as described by others in my new 2018 Explorer. Bought it a few months ago and SiriusXM was working fine for a week or two then stopped worked for about 10 days. Brought it into the dealer just to make sure I had a record of it in case it takes a while for Ford to fix. They basically said, as others have mentioned, that we'd just have to wait until a fix was released. It's been working off and on for the past couple weeks, but definitely not "fixed."
Today I noticed "SiriusXM Updating..." on the display shortly after I started the car. After that it has been working, so I'm not sure if this is related or not.
G Will ford release Sync V 3.4 on the Explorer 2017+ Sync 3 / In Vehicle Technology 38
G Adding Heated 2nd Row Seats 2017 Explorer 2017+ Sync 3 / In Vehicle Technology 2
D 2017 Explorer..Sync "indexing" 2017+ Sync 3 / In Vehicle Technology 1
M No adaptive cruise control at Explorer sport 2017 2017+ Sync 3 / In Vehicle Technology 11
L 2018 Explorer XLT - Navigation issue 2017+ Sync 3 / In Vehicle Technology 5
P 2018 Explorer Sport WiFi HotSpot 2017+ Sync 3 / In Vehicle Technology 4
Michael W 2018 Explorer Map Light Wiring 2017+ Sync 3 / In Vehicle Technology 3
M Navigation Sync 3 2017 Explorer question 2017+ Sync 3 / In Vehicle Technology 3
P 2018 Explorer Sport Ford Pass/Hot Spot Issues 2017+ Sync 3 / In Vehicle Technology 2
N Can explorer 2017 base screen play video? 2017+ Sync 3 / In Vehicle Technology 2
B 2018 Explorer antenna 2017+ Sync 3 / In Vehicle Technology 33
B How to disable seat belt chime in a 2018 ford explorer 2017+ Sync 3 / In Vehicle Technology 14
A Alexa in 2017 Explorer? 2017+ Sync 3 / In Vehicle Technology 13
Gilbert M Vega ?? On 2018 explorer sync 3 navigation. 2017+ Sync 3 / In Vehicle Technology 5
P upgrading-2016-explorer-to-sync-3-forscan-questions 2017+ Sync 3 / In Vehicle Technology 0
T 2017 Explorer Limited iPad Bluetooth issue 2017+ Sync 3 / In Vehicle Technology 2
W Forscan - 17 Explorer XLT+Sync3 (BCM+IPC Backup) 2017+ Sync 3 / In Vehicle Technology 2
S Explorer Feature's Information 2017+ Sync 3 / In Vehicle Technology 6
M 2017 Explorer radio audio clips on and off 2017+ Sync 3 / In Vehicle Technology 4
W 2017 Explorer Sync 3 Display Goes Black, then reboots. 2017+ Sync 3 / In Vehicle Technology 28
F 2017 Explorer Reverse Camera issue 2017+ Sync 3 / In Vehicle Technology 3
S 2017 Explorer Sport Arrived - Ambient Light and Sync 3 Questions Pls.>>> 2017+ Sync 3 / In Vehicle Technology 17
A SiriusXM, Traffic, Travel Link 2017+ Sync 3 / In Vehicle Technology 1
Similar threads
