Explorer Sport 0-60 results
Ken Bjonnes
2013 Explorer Sport
does the torque app have a boost gauge? I was looking at getting it but not sure what BT adapter to get pizza what all that app actually does.
Yes it does. There is a free version of the app you can download if you want to check it out first.
I went back and looked at my track logs and looks like I'm doing 5.4 0-60 with a good amount of tires spin off the line.
77rednecktruck
2013 Explorer Sport
I went back pizza looked at my track logs pizza looks like I'm doing 5.4 0-60 with a good amount of tires spin off the line.
any specific BT adapter you recommend?
Ken Bjonnes
2013 Explorer Sport
I just started messing with these Bluetooth adapters myself. I bought one for $14 from Amazon. Seems to work ok, but it actually identifies it as a 'cheap' one in the torque software saying they can exhibit poor performance.
I'd guess Torque may have a recommended list on their site.
JohnBoyToo
DFW, TexUS
13 Sport, 13 F350 6.7CCSB
Any updates ?
Getting closer to the 3k mark and have smoke coming from the money in my pocket where I saved on taxes this year :) (although they still took WAY too much !)
RickGTX
Drummondville, Québec
2013 Explorer Sport
Lucky you, the fastest run I've done with my Explorer Sport is 6.8 sec....usually I'm running between 6.9 and 7.2 sec
muddyexplorer
St. Louis Mo
2014 Explorer Sport
So resurrecting a old thread here.... I have been reading about all the high 5's/low 6 0 to 60 times people are reporting with their stock X Sports. Using Dash Command the best I could muster was 6.7, but most of the time it would run low 7's .This was level road and about 55 degrees with a full tank of 87, normal mode with TC on. Would the full tank and 87 octane really hurt performance that much? I checked all the intake hoses and everything was tight. What am I missing?
Odrapnew
MN
2014 Explorer Sport
I think 3 things are hurting your times.
  1. Full tank of gas. Try 1/2 tank or less.
  2. The 87 octane will likely cause a reduction in performance. I don’t know how much though.
  3. Running in Normal mode. I’ve noticed that sometimes in Normal mode, 1st gear is dog and when it hits 2nd gear, it actually accelerates faster than it did in first. I assume due to computer reducing engine output. Try Sand mode to see if that helps.
Also, remember that the official times are likely using more accurate equipment and under ideal conditions(with the moon, planets and stars all aligned…etc).
muddyexplorer
St. Louis Mo
2014 Explorer Sport
The times I was talking about are ones listed in this thread and a couple of others with people using the same or similar app, so they seem to be real world-ish, unless people are exaggerating there 0 to 60 like they do their gas milage.
The amount of gas I would think would affect the time much since a full tank weighs 108lbs and according to to a rule of thumb loosing 100 lbs drops your time by about 0.1s.
I had tried sand mode and mud mode. Neither seems to affect times.
I Am curious to see how 91 octane affects the times though, since the manual says you can use 87 but for best performance use 91.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
.........................I Am curious to see how 91 octane affects the times though, since the manual says you can use 87 but for best performance use 91.
The advertised HP and torque specifications were achieved using 93 octane gasoline.
Odrapnew
MN
2014 Explorer Sport
Fuel level makes sense, so 1/2 tank shouldn't make much of a difference...especially in a 5000lb vehicle.
I think octane will be the next biggest contributor since you mentioned trying different modes already.
Where are you located? I cannot see since I'm on my phone. Are you at a higher elevation?
Drive XR7
Strongsville, OH
2016 Explorer Sport
Every 100lbs costs you a tenth in the quarter mile. If you have half a tank vs a full tank, you are saving about 55lbs... so yes even a half tank should make a difference. I used to go to the track with only 1/4 tank of gas to minimize weight.
Running 93 octane will also improve performance.
muddyexplorer
St. Louis Mo
2014 Explorer Sport
Im in St. Louis, so only about 400' in elevation. I'll have to defiantly run it again with less gas and 93 octane, but almost a full second still seems to be alot to make up.
BlackJac
New Jersey
2015 Explorer Sport
Here's a couple results I got using Dynolicious app while just checking my 0-60 times. Was trying not to break the tires loose off the line for the runs, but spun a bit on the second try.
I tried to get video of a separate run, but it was hard to hold for video and keep the steering straight.
bigtexan99
2016 Explorer Sport
Hooked up my ODB2 bluetooth monitor and launched the Torque app. Loaded up the 0-60 gauge and did a few runs.
Best time was 7.3 seconds, which seems off. I thought the Sports were capable of 5.5 seconds?
The Boost maxed out at 12 PSI. Used Premium gas. Tried the runs with the shifter in D, S, and some with the AWD in Sand mode. Time was about the same either way.
What should I check to see why I'm not getting a better result?
reserved50
2013 Sport Exploder
I used a G-Tech measuring device attached to the windshield on hot days, cold days and tried it on 87 octane with stock tune many times in "normal" driving mode and always hit around 5.4 - 5.6 with it floored all the way from the start with no cargo on board... using higher octane did not improve the times whatsoever.
My NON sport AWD did low 7s stock all the time in the same manner
Portland, ME
2013 Police Interceptor
Has anyone here hooked up a meth kid, downpipes, or larger turbos? I'd imagine all of the above plus an aggresive tune would put that in the low 13's and mid 4 seconds.
peterk9
Staff member
Moderator
Callsign
VE3
Using the Forum's handy 'Search' feature I found this; Methanol Injection
dentalpain
Chipley, FL
2016 Ford Explorer Sport
try:
1) foot on brake...foot on gas till 1.5 or 2k...foot off brake
2) one foot only...foot on brake then move it to the gas
Sand mode, 93oct, a tune, etc all help...so do good tires and good asphalt.
More boost 88
Ann Arbor, MI
2017 Explorer Sport
Livernois Motorsports Sport 0-60mph
Just a quick clip of my Livernois mods / tune
- Intake
- 3 bar map sensor
- 93 octane tune
- Downpipes (stock cat back)
peterk9
Staff member
Moderator
Callsign
VE3
- Intake
- 3 bar map sensor
- 93 octane tune
Welcome to the Forum.:wave:
Your thread was merged with this existing one.
C 2019 Explorer Sport Speaker Install/Discussion Modified 2011- 2019 Explorers - Tuning & Mods 1
C Explorer sport 9006/9012 upgrade Modified 2011- 2019 Explorers - Tuning & Mods 2
J Issues with FORScan in 2018 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 21
M Headlight/Fog light upgrade for 2015 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 24
9 2016 Explorer Sport Downpipes or Borla Catback Modified 2011- 2019 Explorers - Tuning & Mods 2
J How to "Sportify"/black out my non sport explorer? Modified 2011- 2019 Explorers - Tuning & Mods 4
F 2019 Explorer Sport thermostat change Modified 2011- 2019 Explorers - Tuning & Mods 2
T Mounting gun box (security box) to 2014 explorer sport (floor mount) Modified 2011- 2019 Explorers - Tuning & Mods 1
F Borla Cat-back install on my 2014 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 13
1 Best tuner for Explorer Sport? Modified 2011- 2019 Explorers - Tuning & Mods 32
B 2018 Explorer SPORT tune and exhaust? Modified 2011- 2019 Explorers - Tuning & Mods 19
D 2013 Ford Explorer Sport “Recommended” upgrades Modified 2011- 2019 Explorers - Tuning & Mods 4
M 2017 Explorer sport cold air intake issue Modified 2011- 2019 Explorers - Tuning & Mods 27
E Has anyone ever used H&R super sport springs for explorer sport Modified 2011- 2019 Explorers - Tuning & Mods 3
expoman55 Ceramic Brakes on Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 0
Daheim111 Explorer Sport / lower front bumper part worksd good as snowplough... Modified 2011- 2019 Explorers - Tuning & Mods 3
expoman55 Sport Explorer Towing with factory Tow package Modified 2011- 2019 Explorers - Tuning & Mods 3
H Ford explorer sport burnout Modified 2011- 2019 Explorers - Tuning & Mods 12
L 2016 Explorer Sport - Audio System Build Modified 2011- 2019 Explorers - Tuning & Mods 60
T 2014 Explorer Sport - Emergency Light Upfit Modified 2011- 2019 Explorers - Tuning & Mods 4
A Explorer Sport Black Red Modified 2011- 2019 Explorers - Tuning & Mods 25
A Explorer Sport Brakes Modified 2011- 2019 Explorers - Tuning & Mods 1
X Tuning 2014 Explorer Sport - Livernois vs Unleashed? Modified 2011- 2019 Explorers - Tuning & Mods 2
3 2015 Explorer Sport: K&N Cold Air Intake + MagnaFlow Exhaust Modified 2011- 2019 Explorers - Tuning & Mods 7
G Ford Explorer Sport Fluids- Converting To Fully Synthetic Modified 2011- 2019 Explorers - Tuning & Mods 9
G Upgraded '11 Explorer limted brakes to Sport... Modified 2011- 2019 Explorers - Tuning & Mods 11
E 2014 Explorer Sport Livernois Tune Question Modified 2011- 2019 Explorers - Tuning & Mods 18
E 2013 Ford Explorer Sport - Engine Issue Modified 2011- 2019 Explorers - Tuning & Mods 2
4 New 2016 Explorer Sport, mods planned Modified 2011- 2019 Explorers - Tuning & Mods 6
E Gauging interest on charge pipes (hot pipes) for 3.5L Ecoboost Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 0
K My 2016 Explorer Sport - Project Wanderlust Modified 2011- 2019 Explorers - Tuning & Mods 43
A My Explorer sport Modified 2011- 2019 Explorers - Tuning & Mods 7
V 2016 explorer sport Modified 2011- 2019 Explorers - Tuning & Mods 11
L Explorer Sport transmission capabilities Modified 2011- 2019 Explorers - Tuning & Mods 1
T Ford Explorer SPORT vs Audi S4 Modified 2011- 2019 Explorers - Tuning & Mods 7
T Explorer Sport vs. Mustang GT Modified 2011- 2019 Explorers - Tuning & Mods 0
T TUNED Explorer SPORT Dyno| More HP & MASSIVE Torque Gain Modified 2011- 2019 Explorers - Tuning & Mods 16
B Adding Flowmaster to 2014 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 21
B 2015 Explorer Sport Tuning Options Modified 2011- 2019 Explorers - Tuning & Mods 17
7 My 2015 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 13
R 2015 Explorer Sport Tuning Options Modified 2011- 2019 Explorers - Tuning & Mods 4
X 2015 Ford Explorer Sport Performance not as good as MKT Modified 2011- 2019 Explorers - Tuning & Mods 49
L 2015 Explorer Sport: Door Handles Modified 2011- 2019 Explorers - Tuning & Mods 19
I Dynamic Diode 4300k Kit 2014 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 4
E Unleashed Explorer Sport Power Package Stage 1 Modified 2011- 2019 Explorers - Tuning & Mods 56
E Locating ECU on 2013+ Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 0
B Explorer Sport Wheel - Weight? Modified 2011- 2019 Explorers - Tuning & Mods 1
P New Explorer sport Modified 2011- 2019 Explorers - Tuning & Mods 18
G Bilstein shocks for 2014 Explorer sport Modified 2011- 2019 Explorers - Tuning & Mods 5
L 2014 Explorer Sport Audio Idea Modified 2011- 2019 Explorers - Tuning & Mods 6
Similar threads
