How to: Explorer Sport EB convert to vent to atmosphere with factory blow off valves
Rican219
2015 Explorer Sport
Here you go guys just made this video. Thanks for the information on this walk through it was perfect.
I did both front and rear.
This is Wifey's 2015 Explorer sport and this was it's first mod.
Sbilisko
2014 Ford Explorer Sport
I did this mod a while back and misplaced the hoses. I wanted to put them back on but I am going to have to order new ones. Does anyone know what part number they are? Thanks
BillyG2014Sport
Delawhere?
I only did the front hose and eventually got tired of hearing it go off too often. I put my hose back on and used aftermarket clamps to secure it. The sound gets old after awhile in my opinion.
LuisMarin
Cape Cod, Ma
2016 Explorer Sport
Hi guys
I couldn't find suitable cap and i was so excited to hear that sound so i did it last night with what was useful.
BUT in test run there was no new sound:(
any help?
Hey did you ever find out what was wrong? I'm kind of curious to know what you did wrong or maybe is your motor not boosting? Anyways.... No one never answered you back and you never posted anything following your original.... So I must ask.
corpflyboy
Melbourne, Florida
Just a FYI
While at the oil change garage today, I noticed the two open end hoses that I had open to the atmosphere were oozing with a little bit of oil residue. I will be reinstalling these hoses as soon as the engine cools down. I dont want that residual oil to start cooking on exhaust parts and making an already stinky car at full power smell even worse. Not worth the Whoosh sound anymore.
Buzz
613GT500
Ontario, Canada
2016 XC90 T8 R-Design
Just a FYI
Buzz
Bumping this old post, as I recently modified mine to VTA and the concern you brought up is exactly why some owners installed a catch can.You should look into this considering you are seeing oil and it is now making its way into your intake manifold.
midnightsun
2016 Explorer Sport
Loving the Choo Choo / blowoff noise. Lucky for me the back pipe had already blown off after 500 miles from new. Removal was easy. ;)
jthompson88
jacksonville NC
2016 Explorer Sport
Just did this mod on mine and while in the process of doing it I too noticed oil residue in the tubing (both the recirc tubes and the intake tubing). Not a lot, just some residue. Is this a common issue with these engines or cause for concern. Our sport only has 10,XXX miles on it and no other mods.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Not that familiar with the turbo setup but when you mentioned intake tubing is that the air intake to the filter? There have been issues with that in the past on non turbos.
jthompson88
jacksonville NC
2016 Explorer Sport
I guess maybe I am using the wrong phrasing. It was the tube coming off the rear turbo that both of the bov recirculation hoses plug into. Just figured it was some kind of intake tube. Also the rear BOV has a little oil residue inside of the vent opening. Again nothing crazy. Just curious if it was a known issue or I should maybe be concerned.
ggifford
Chester, CA
2016 Explorer Sport
Just vented to atmosphere the forward blow off valve. No additional HP, but she sure sounds faster! Ha. Love it.
613GT500
Ontario, Canada
The pipe connected to the turbos and intercooler is called a CAC (cold air charge) pipe.
The oil residue you see, is PCV (positive crankcase ventilation) blowby vapor, that you do not want recirculated back into the intake manifold; as it increases carbon buildup in our EB engines.
This is one of the main reasons, I decided to vent the blowoff valves to the atomosphere and I will be installing a catch-can also.
deadlyapp
Los Angeles, CA
2015 Explorer Sport
Bumping this thread for curiosity sake. Has anyone installed an aftermarket blow off valve, such as the HKS SSQV or similar for a different sound/pitch? I see turbosmart is actually selling a kit that is specific to the 3.5L ecoboost (https://www.summitracing.com/parts/tbs-ts-0215-1371/overview/) but there is no real reason for one over another as long as the springs are correct for the boost.
Also - it appears that the stock recirculation valves are electrically operated. I'm assuming this is done via throttle position (negative voltage from throttle sensor opens valve), but I see no real reason why we can't do it as a vacuum operated valve (which is what most BOV are triggered by). Does anyone know if you get a CEL if the recirculation valves are unplugged?
Azd122979
Wyoming
'17 Ford Explorer Sport
I personally only did the front one as it was easy and still sounds good. I just left the rear one factory.
How long have you been running with jus the front one done? Have you ran across any issues? Is this safe to do just one versus both? Thanks in advance!
BubbaG
Hebbronville, TX
2018 Explorer Sport
Anyone having issues with the residual oil coming out of the BOV's? Possibly a result from the pcv or ccv?
peterk9
Staff member
Moderator
Callsign
VE3
^^ Welcome to the Forum.:wave:
613GT500
Ontario, Canada
Not sure if the catch can was simply very efficient, but I found no more oil residue when I was putting everything back priority to selling the EX.
BubbaG
Hebbronville, TX
2018 Explorer Sport
How and what did you use for the catch can?
R Steeda springs (555 8202) vs Sport explorer springs (DB5Z-5310-K) in my XLT with B6 install Modified 2011- 2019 Explorers - Tuning & Mods 5
A New Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 1
O 2016 Explorer sport Modified 2011- 2019 Explorers - Tuning & Mods 3
Fasterdamnit! Help! Power Stop Z23-1508 pads do not fit my '14 Explorer Sport front calipers Modified 2011- 2019 Explorers - Tuning & Mods 10
C 2019 Explorer Sport Speaker Install/Discussion Modified 2011- 2019 Explorers - Tuning & Mods 1
C Explorer sport 9006/9012 upgrade Modified 2011- 2019 Explorers - Tuning & Mods 2
J Issues with FORScan in 2018 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 21
M Headlight/Fog light upgrade for 2015 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 24
9 2016 Explorer Sport Downpipes or Borla Catback Modified 2011- 2019 Explorers - Tuning & Mods 2
J How to "Sportify"/black out my non sport explorer? Modified 2011- 2019 Explorers - Tuning & Mods 4
F 2019 Explorer Sport thermostat change Modified 2011- 2019 Explorers - Tuning & Mods 2
T Mounting gun box (security box) to 2014 explorer sport (floor mount) Modified 2011- 2019 Explorers - Tuning & Mods 1
F Borla Cat-back install on my 2014 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 14
1 Best tuner for Explorer Sport? Modified 2011- 2019 Explorers - Tuning & Mods 32
B 2018 Explorer SPORT tune and exhaust? Modified 2011- 2019 Explorers - Tuning & Mods 19
D 2013 Ford Explorer Sport “Recommended” upgrades Modified 2011- 2019 Explorers - Tuning & Mods 4
M 2017 Explorer sport cold air intake issue Modified 2011- 2019 Explorers - Tuning & Mods 27
E Has anyone ever used H&R super sport springs for explorer sport Modified 2011- 2019 Explorers - Tuning & Mods 3
expoman55 Ceramic Brakes on Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 0
Daheim111 Explorer Sport / lower front bumper part worksd good as snowplough... Modified 2011- 2019 Explorers - Tuning & Mods 3
expoman55 Sport Explorer Towing with factory Tow package Modified 2011- 2019 Explorers - Tuning & Mods 3
H Ford explorer sport burnout Modified 2011- 2019 Explorers - Tuning & Mods 12
L 2016 Explorer Sport - Audio System Build Modified 2011- 2019 Explorers - Tuning & Mods 60
T 2014 Explorer Sport - Emergency Light Upfit Modified 2011- 2019 Explorers - Tuning & Mods 4
A Explorer Sport Black Red Modified 2011- 2019 Explorers - Tuning & Mods 25
A Explorer Sport Brakes Modified 2011- 2019 Explorers - Tuning & Mods 1
X Tuning 2014 Explorer Sport - Livernois vs Unleashed? Modified 2011- 2019 Explorers - Tuning & Mods 2
3 2015 Explorer Sport: K&N Cold Air Intake + MagnaFlow Exhaust Modified 2011- 2019 Explorers - Tuning & Mods 7
G Ford Explorer Sport Fluids- Converting To Fully Synthetic Modified 2011- 2019 Explorers - Tuning & Mods 9
G Upgraded '11 Explorer limted brakes to Sport... Modified 2011- 2019 Explorers - Tuning & Mods 11
E 2014 Explorer Sport Livernois Tune Question Modified 2011- 2019 Explorers - Tuning & Mods 18
E 2013 Ford Explorer Sport - Engine Issue Modified 2011- 2019 Explorers - Tuning & Mods 2
4 New 2016 Explorer Sport, mods planned Modified 2011- 2019 Explorers - Tuning & Mods 6
E Gauging interest on charge pipes (hot pipes) for 3.5L Ecoboost Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 0
K My 2016 Explorer Sport - Project Wanderlust Modified 2011- 2019 Explorers - Tuning & Mods 47
A My Explorer sport Modified 2011- 2019 Explorers - Tuning & Mods 7
V 2016 explorer sport Modified 2011- 2019 Explorers - Tuning & Mods 11
L Explorer Sport transmission capabilities Modified 2011- 2019 Explorers - Tuning & Mods 1
T Ford Explorer SPORT vs Audi S4 Modified 2011- 2019 Explorers - Tuning & Mods 7
T Explorer Sport vs. Mustang GT Modified 2011- 2019 Explorers - Tuning & Mods 0
T TUNED Explorer SPORT Dyno| More HP & MASSIVE Torque Gain Modified 2011- 2019 Explorers - Tuning & Mods 16
B Adding Flowmaster to 2014 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 21
B 2015 Explorer Sport Tuning Options Modified 2011- 2019 Explorers - Tuning & Mods 17
7 My 2015 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 13
R 2015 Explorer Sport Tuning Options Modified 2011- 2019 Explorers - Tuning & Mods 4
X 2015 Ford Explorer Sport Performance not as good as MKT Modified 2011- 2019 Explorers - Tuning & Mods 49
L 2015 Explorer Sport: Door Handles Modified 2011- 2019 Explorers - Tuning & Mods 19
I Dynamic Diode 4300k Kit 2014 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 4
E Unleashed Explorer Sport Power Package Stage 1 Modified 2011- 2019 Explorers - Tuning & Mods 56
E Locating ECU on 2013+ Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 0
Similar threads
