  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
Explorer Sport - fuel?
What grade of fuel do you use in your Sport?
  • Regular 87
    Votes: 34 30.9%
  • mid grade 89
    Votes: 8 7.3%
  • Premium 91-93
    Votes: 58 52.7%
  • I use more than one grade
    Votes: 5 4.5%
  • I'm tuned I have to run Premium
    Votes: 6 5.5%
  • Total voters
    110
JE
Londonderry, NH
2015 Explorer Sport
Also note that the engine will adjust to LOWER octane nearly immediately when knocking is sensed but it will be slower to adjust for a HIGHER octane. There have been other conversations on what will cause the engine to readjust to higher octanes but it sounds like resetting the ECM (by unhooking the battery for a while) or making some runs at WOT will speed the process.
Note that all the reports that say there is no advantage to using higher octane fuels have a phrase like "unless your vehicle is designed for it." The Ecoboost in our Ex Sports IS designed for it, but can also self-adjust for lower octane fuels.
And it's not alone in that. My 2005 Chevrolet is capable of the same adjustment but with a few different behaviors (that probably aren't of much interest on a Ford forum.)
bigdude2468
2014 Explorer XT
Keep in mind the added performance using mid range or premium comes with a significant increase in cost. Using today's cost its 25% more for premium over 87 octane. Considering the added cost only provides a slight increase in performance, no increase in MPG, I don't see the point.
1995E
Maryland
95 + 11 Ex both XLT
So following the chain of thought, would 94 octane result in any additional power? I believe that running 87 would lower power to protect the engine because of potential knocking, but I've also read a thread somewhere in here where it's stated that running 87 also lowers MPG. The idea of lowering one's MPG because of a lower grade of gas doesn't make sense, although with direct injection I'm less sure of that answer.
The tranny is the weak part of this setup and has been stated by Ford during an interview as part of the reason why the torque is so much lower than the in the F-150 (the Explorer transaxle vs the F-150 direct transmission to the backend). Otherwise, this vehicle would be much more tunable.
The higher octane is so that the car can perform at max performance without knocking and reducing power. If the engine is designed for to have its max power made at 93 octane. An octane like 94 would just be more insurance that it won't knock, but it won't increase performance because the engine isn't tuned to run at pressures higher than what 93 octane fuel would accommodate.
The only way you can get higher performance is when you use a tune that creates engine environments that require octane higher than the designed 93 and the use of the higher octane is to prevent the engine from combusting itself to death.
Also, don't confuse higher octane with more energy. The only difference is between the fuels is the ability to reduce pre-detonation.
Energy density between all octane fuels is the same, the only time energy density would be different is if you had ethanol in the fuel which has a lower energy density.
As quoted from wikipedia about compression ratio:
"A high compression ratio is desirable because it allows an engine to extract more mechanical energy from a given mass of air-fuel mixture due to its higher thermal efficiency. This occurs because internal combustion engines are heat engines, and higher efficiency is created because higher compression ratios permit the same combustion temperature to be reached with less fuel, while giving a longer expansion cycle, creating more mechanical power output and lowering the exhaust temperature."
Unless if you're increasing compression ratios, 93 is the max you'd ever need in these cars.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
I'm with you. Paying an extra 25% isn't worth the minimal performance improvement for me either. I don't tow or drive hard. The extra $$ is better off in my pocket than the oil company's and the government's. :):thumbsup:
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
The extra octane makes a noticable difference if you bought a tune from one of the providers.
I use Chevron 94 and it's significant, but you're right it's at a cost.
Also noticeable on the exhaust tips, I see none of the black carbon deposits I did with 87.
Rick New Ford Explorer Sport: Fuel-Efficient, High-Performance SUV Stock 2011 - 2019 Ford Explorer Discussion 318
W 2017 Explorer Sport - Rumbling when when turning. Stock 2011 - 2019 Ford Explorer Discussion 6
M 2018 Ford Explorer Sport buzzing sound Stock 2011 - 2019 Ford Explorer Discussion 2
A Sport Appearance wheels on Sport Explorer Stock 2011 - 2019 Ford Explorer Discussion 2
T 2015 Explorer Sport vs. 2016+ Sport...Disappointing Test Drive. Stock 2011 - 2019 Ford Explorer Discussion 5
K New wheels and Tires in 2016-19 explorer sport Stock 2011 - 2019 Ford Explorer Discussion 1
T 2013 Ford Explorer Sport Whistling during acceleration Stock 2011 - 2019 Ford Explorer Discussion 0
J What happened to my 2017 Explorer Sport??? (Turbo and Engine issues) Stock 2011 - 2019 Ford Explorer Discussion 11
T 2013 Explorer Sport Whistling Stock 2011 - 2019 Ford Explorer Discussion 0
M 2016 Explorer Sport Coolant Flush Stock 2011 - 2019 Ford Explorer Discussion 8
R 2017 Explorer Sport 2nd row console Stock 2011 - 2019 Ford Explorer Discussion 7
F New member...ting/pop/click noise-front half shaft 2015 Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 10
F 2017 Explorer Sport takeoff surging Stock 2011 - 2019 Ford Explorer Discussion 8
N Help with Tire Size for Explorer Sport 2014 Stock 2011 - 2019 Ford Explorer Discussion 8
D 2016 Ford Explorer Sport seat uncomfortable Stock 2011 - 2019 Ford Explorer Discussion 1
B 2016 Explorer Sport Driver seat heater working for back but not seat? Stock 2011 - 2019 Ford Explorer Discussion 3
B Explorer Sport ac question Stock 2011 - 2019 Ford Explorer Discussion 2
C 2016 Ford Explorer Sport, Passenger floorboard completely flooded Stock 2011 - 2019 Ford Explorer Discussion 11
K 16' Explorer Sport Parking Brake Adjustment? Stock 2011 - 2019 Ford Explorer Discussion 11
N 2016 Explorer Sport lugging issue. Stock 2011 - 2019 Ford Explorer Discussion 4
D About to join the Ford Explorer Sport family.. Stock 2011 - 2019 Ford Explorer Discussion 7
R 2018 Ford Explorer Sport electrical issues Stock 2011 - 2019 Ford Explorer Discussion 2
M 2016 Explorer Sport Lemon Stock 2011 - 2019 Ford Explorer Discussion 4
S Vent To Atmosphere (VTA) mod Explorer Sport - issues Stock 2011 - 2019 Ford Explorer Discussion 9
B 2015 Explorer sport water pump replacement Stock 2011 - 2019 Ford Explorer Discussion 12
E 2016, 2017, 2018 Explorer Sport Trim- Why? Stock 2011 - 2019 Ford Explorer Discussion 33
D Gas Additive for Ford Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 6
M Explorer Sport purge valve location? Stock 2011 - 2019 Ford Explorer Discussion 11
B Noobie with an issue 2017 explorer sport Stock 2011 - 2019 Ford Explorer Discussion 13
B 2014 Explorer Sport Horn location Stock 2011 - 2019 Ford Explorer Discussion 13
S 2017 Explorer Sport shifting hard Stock 2011 - 2019 Ford Explorer Discussion 5
S 2013 Explorer sport airbag light on, B0002 code assistance needed Stock 2011 - 2019 Ford Explorer Discussion 2
A 2014 Explorer Sport Turbo feed line leak. Stock 2011 - 2019 Ford Explorer Discussion 1
D 2017 Ford Explorer Sport stock exhaust Stock 2011 - 2019 Ford Explorer Discussion 10
M 2016 Explorer Sport Tail Light Part? Stock 2011 - 2019 Ford Explorer Discussion 3
B '14 Explorer Sport - Current draw with engine off after AC stopped blowing cold Stock 2011 - 2019 Ford Explorer Discussion 5
E Comparisons between 2014-2015 models vs 2016 and up Ford Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 20
P 2016 Ford Explorer Sport brake job Stock 2011 - 2019 Ford Explorer Discussion 0
G Part help - 2013 explorer sport Stock 2011 - 2019 Ford Explorer Discussion 3
K 2013 Explorer Sport muffler leak question Stock 2011 - 2019 Ford Explorer Discussion 7
94Eddie Would like feedback on the Explorer Sport model Stock 2011 - 2019 Ford Explorer Discussion 19
F 2019 Explorer Sport VS Car Wash Stock 2011 - 2019 Ford Explorer Discussion 28
H 2013-2015 Explorer Sport Questions ( new to the vehicle ) Stock 2011 - 2019 Ford Explorer Discussion 3
J 2014 Explorer Sport electrical problems Stock 2011 - 2019 Ford Explorer Discussion 6
J 2017 explorer sport tire size Stock 2011 - 2019 Ford Explorer Discussion 14
S 2014 Explorer Sport Rack and Pinion Torque Specs Stock 2011 - 2019 Ford Explorer Discussion 4
O Does the 2013 Explorer Sport have a transfer case oil cooler? Stock 2011 - 2019 Ford Explorer Discussion 4
G 2013 explorer sport radiator vs N/A V6 Stock 2011 - 2019 Ford Explorer Discussion 4
S Spark Plug job on Explorer Sport 3.5L Ecoboost Stock 2011 - 2019 Ford Explorer Discussion 26
J 2019 Explorer Sport Horn Sound Stock 2011 - 2019 Ford Explorer Discussion 75
Similar threads
