I've parted out three 1st generation Explorer Sports and have glass, exterior trim, and interior parts for sale. Very reasonable prices - just hoping to help keep these great vehicles on the road. Contact me for anything you need. You'll be surprised by what I have!
I am looking for the plastic piece where the passengers side sun visor clips into for my wife's 99 Sport. I had the headliner out to recover the sliding sunroof shade & broke this piece on reassembly. The interior is gray, but I do not care what color you have if you do not have the gray, I can paint it. Here is a picture of the piece I need.
Too bad . . . I had a gray one exactly like yours that I didn't pull off a car that I just had towed away, thinking I'd pulled just about everything that might be usable.
I do have a tan one, but it's for the single-visor design. The photo shows the piece designed for the double visor, so what I have won't work. Sorry.
Any hints on removing the sun-roof insert? Like all of them, the material on mine has pretty much rotted. I've heard/read everything from removing the entire headliner to removing the glass to pull the piece out through the roof. Both sound like a royal pain, with a lot of brittle plastic parts that are too easy to break.
The headlining material has come partially unglued from the shade on the power sunroof. It looks like it would be a lot easier to re-glue with the shade removed. How do I get it out? Also, best glue for re-gluing?
Last weekend I removed the headliner in my wife's 99 Sport & today I removed the sunroof glass, the water catch pan, & the sliding sunroof shade so I could recover it. I used a putty knife to remove all the old foam from the cover then sprayed a couple coats of 3M Super 77 spray adhesive that ?I...
www.explorerforum.com
Just be very careful, I used a door panel remover similar to this one to remove the 2 side flat trims that cover the sunroof glass bolts. https://www.amazon.com/dp/B00470JPDW/?tag=serious-20
I used a small straight blade screwdriver to release the 2 sliders that hold the sliding sunroof shade in the track.
