Welcome to the Forum.Can someone explain to me how the new navigator, and the 2017 raptor are using (I think the same engine) but getting way more power? Is it just as simple as larger turbos?
Different engine tunes to get the different HP/Torque numbers...same basic motors, just the tune/fuel map is changed.
And...because?
Engineers achieved the gains in power and efficiency with higher-boost turbos, port fuel injection (in addition to existing direct injection), Ford-first electronically controlled turbo waste gates, weight-saving hollow camshafts fitted with roller-finger follower valvetrains and standard auto stop/start. Overall, the engine is 4 lbs. (1.8 kg) lighter compared with its predecessor.
Mazuchowski says the Borg Warner-supplied turbos feature upgraded turbine wheels made of lightweight Mar-M-247 super-alloy that are more responsive. Boost is up 2.5 psi (.17 bar) to 16 psi (1.1 bar) using the same 51-mm (2-in.) diameter turbine wheels but employing more sharply angled vanes.
Well I am not sure why you would post that it is just tuning when I posted the link to what is different in this thread.
Direct from the link:
So new turbo, 2 injectors per cylinder instead of 1, different wastegate, different camshaft..
Not sure how this equates to just "tuning". This is a 2nd gen motor.
Lol, it kind of looks like a link for advertisement . That's why I missed itSorry, I didn’t see your link
