Explorin'VA
- September 7, 2012
- P-twn
- '94 xlt
I'm making this thread to keep track of my progress and for support if I find myself in over my head. My A4LD is giving me problems after many years of good service, so I think now is the time to upgrade with my newly acquired M5OD. I've never replaced a transmission so I'm making sure I have all the parts I need before I tear the auto out.
Here are the parts I have:
-M5OD with wire harness
-Shifter with floor plate
-Starter from a 1992 Explorer
-ECM from a 1994 Navajo (California)
-Clutch and brake pedal assembly
-Clutch master cylinder (used)
-Clutch fluid reservoir (used)
-Luk clutch kit with pilot and release bearing (new)
-Flywheel (new)
I also have a new rear main crankshaft seal which I'll replace when the trans is out. The slave cylinder in the transmission currently is still fairly new, but I think I'm going to replace it before the M5OD goes in. The o'reilly auto up the street should have that in stock. So now I technically have everything I need to get started. I will keep the thread updated as I make progress.
-Flywheel (new)
