gavin
- September 27, 2002
- Anchorage, Alaska
- '97 Explorer XLT AWD 5.0L
got this from a guy on a local board, who did this with his 76 EB. It will also work on all TTB suspensions (of course)
It replaces the rad arm bushings with a johnny joint, eliminating the bind from the bushings. I know it will come out to be a bit more expensive, but might be worth it.
"When I extended the radius arms on my 78 bronco I used a lower arm from a Rubicon Express TJ lift with the johnny joint. I cut the rubber bushing end off, which leaves the arm about 14" long and slid the arm over the stud at the end of the stock radius arm and welded it on. Used CJ shackle reversal brackets as radius arm mounts on the frame. Works great, ramps about 100 better, around 800 or so and the johnny joint is rebuildable and greasable. I'll try to get a picture to put up.
