mrslurp
- September 11, 2009
- Burnham, PA
- 2003 Ranger XLT 4.0L
As I just got my ranger from a private individual, and have no warranty, and the potential for problems in the future (not knowing anything about the prior history of the truck), I have decided to go with an extended warranty. There are 115,000 miles on the truck. I have done some research, and Warranty Direct seems to have very high ratings. $2,086 gets me 3 years/50k miles.
Covers:
Engine (a) The following lubricated internal parts: pistons, pins & rings, connecting rods & bearings; crankshaft & main bearings; camshaft, followers & cam bearings; push rods, valves, springs, replaceable guides, seats & lifters; rocker arms, shafts & bushings; timing gear, chain, tensioners & retainers; eccentric shaft; oil pump.
(b) Timing belt; serpentine belt; Water pump: Impeller shaft, bearings, bushings & housing; intake & exhaust manifolds; engine mounts & cushions; engine torque strut; harmonic balancer; flywheel (flexplate) & flywheel ring gear; mechanical fuel pump; dipstick & tube; all pulleys.
(c) All lubricated internal parts of the vehicle manufacturer installed turbocharger or supercharger.
(d) Engine head(s); engine block; cylinder barrels; timing cover; valve
cover(s); oil pan; dipstick & tube.
Transmission (a) All lubricated internal parts contained within the case(s).
(b) Computer modules & solenoids; filler tube & dipstick; vacuum modulator; internal linkage.
(c) Transmission case, transfer case & torque converter case.
Drive Axle (a) All lubricated internal parts contained within the housing(s).
(b) Axle shafts; constant velocity joints (CV); universal joints; drive shafts; locking hubs; locking rings; supports, retainer & bearings.
(c) Differential housing, transaxle housing & final drive housing.
OPTIONAL ENHANCED COVERAGE
ELECTRICAL- Starter Motor, alternator, voltage regulator, power window motors, heater fan and front wiper motor.
AIR CONDITIONING - Compressor Motor, condenser and evaporator, compressor clutch, coil (pulley and hoses are not covered).
Does this seem legit or a good deal? Any other companies you guys go with or prefer?
Covers:
