Mitchs07explorer
- August 14, 2015
- Location
- Idaho
- Meridian, Idaho
- 97 XLT V8 AWD
07 XLT V6
I’m looking for a few opinions on those who have changed out their external timing tensioners. I’m doing a full timing rebuild at the moment, I just got the heads back from the machine shop and am pretty close to putting everything back together. For a little back ground, I’ve had a startup rattle for the last 18 months. I changed out my external tensioners to see if that would make a difference, from what I could tell one of the original tensioners went bad. I used Cloyes tensioners to replace them as I was led to believe that’s the next best option next to motorcraft tensioners which I can’t find. Thing is I still had the startup rattle after I changed them so I assumed my timing guides and internal tensioners were going out. I blew my head gasket on the passenger side head so the engine had to come out anyway and of course at 170k I’m going to change my guides and tensioners regardless.
I pulled the engine and opened it up and to my surprise all of the guides and tensioners looked to be in good shape. When I knocked out the front cassette guide, it hit the garage floor and shattered so I didn’t get to see if it was coming apart. At the very least it was brittle but still looked intact. My new timing kit is a Cloyes and it comes with new tensioners which I’m planning on using but am afraid I’ll still end up with that minor start up rattle again. Has anyone else run into timing chain rattles due to poor quality tensioners and if so what tensioners did you end up going with?
