F150 Coil Seats Install and Shackles for TTB suspension based platforms | Page 2 | Ford Explorer - Ford Ranger Forums - Serious Explorations
JPE16
cambridge, Ontario
1994 2 door
sooooo same procedure and results on a 94 explorer sport? i have yet to get underneith mine so i dunno...lol...any help before i dig in would be great :)
Tbars4
Moderator Emeritus
Elite In Memoriam
anaheim hills,california
95 ranger 4x4/ 91 X 4x4
...it's the same...alot of stock explorers first lifted their trucks this way...good luck...:D
Diz
Las Vegas NV
What year F-150 did those come from i was looking to get the Axle drop brakets and a cheap set of springs but that would be even easier (and cheaper). Also has anyone did a lift and dont need the stock brackets. I am trying to make the brakets and if they work i will not have to buy them.
Tbars4
Moderator Emeritus
Elite In Memoriam
...they are out of the early 90's f150's or can be bought at the dealer for about the above mentioned price, or your local junk yard....i seriously would do this type of lift first...i highly suggest not making your own brackets for the safety of the rest of us on the road...;)
Diz
Las Vegas NV
I will find some then. But did the camber get fixed at the align shop. in the one pic your tires are really leaning up top. If it came out at the shop i will do that with a 3 inch body lift
Tbars4
Moderator Emeritus
Elite In Memoriam
...that did come out at the shop and that is actually 4" lift on that truck...i did the coil spacers under 2" over springs...with that, you need axle pivot brackets...if you read thoroughly thru the thread, everything is spelled out...
...with the f150 coil seats you do not need axle pivot brackets with stock springs, good luck on your project...:D
Tbars4
Moderator Emeritus
Elite In Memoriam
JPE16
cambridge, Ontario
1994 2 door
whats the limit of the stock shocks? do i need new shocks for a 2" lift on my 94 exploder?
Tbars4
Moderator Emeritus
Elite In Memoriam
...it would be a good idea to get 2" over shocks but your x will be fine on the street...;)
JPE16
cambridge, Ontario
1994 2 door
sweet...well the truck wont be a hardcore offroader..just highwya driving and gettin through some snow...i live in the country...soo yeah...lol...
sweet...also...kind of unrelated but...i'm looking to get some wider wheels with a lower offset...what do you guys recommend? i'm lookin at the basic cragar wheels from summit..they're like $40 each..just trying to get a wider track to inhibit the random roll-overs these truck seem to suffer from..and also make it a lil nicer in the snow..
Tbars4
Moderator Emeritus
Elite In Memoriam
...most guys on here have 15x8 wheels with 3.75" back spacing...the rest you will have to search for...good luck on your project...:D
JPE16
cambridge, Ontario
1994 2 door
thanks man! i'll post pics when its done
JPE16
cambridge, Ontario
1994 2 door
so a 15x8 wheel with 3.75 inch backspacing and a 3.30 center bore and 5x4.5 bolt pattern will fit? only reason i ask is that it's not listing it as fitting my truck on their site...
Diz
Las Vegas NV
The axle pivot brackets, are they for the radius bars or do the go someplace else. i would like to go with 2 inch suspension and 3 inch body lift. so was thinking shackels in the rear and coil spacers up front.
86caprirs
Chestermere, Alberta
1992 Explorer 4.0L 4x4 XL
Also mention that the F-150 coil seats are from a early 90's 2x4 not a 4x4.If you are scowering the junk yards.
Tbars4
Moderator Emeritus
Elite In Memoriam
cybergasm
Humboldt Ks
1997 Mountaineer 5.0
So Professor Tbars;) when you installed the spacers did you flip em like you mentioned in the first post or put L on the L and R on the R?
Tbars4
Moderator Emeritus
Elite In Memoriam
...they were flipped, l-r, r-l....they fit with the tab to the rear of the axle arms and they kind of lock in...:D
cybergasm
Humboldt Ks
what i needed to need now to order them:D
Tbars4
Moderator Emeritus
Elite In Memoriam
...let me know how that works out on your already lifted truck...do a writeup, include your current lift mods, and be sure to get a free alignment inspection ahead of time, to make sure you have enough play with the bushings and they will have the size you need when it comes time to align...;)
