F150 spacers/Warrior shackles?? | Ford Explorer - Ford Ranger Forums - Serious Explorations
John Doe
Dayton, OH
'94 EB
Hey guys,
I had a couple questions about the Warrior shackles and F150 coil spacers that many of you use on your Explorers. I have a '94 Explorer and already have a 3" body lift, but would like a few more inches of clearance without spending the money for a suspension lift. About how much $$ am I looking at spending for the shackles and spacers? Is there somewhere online where I could buy them? Also, about how much clearance will I gain with them and how hard are they to install? Thanks.
-Mike
yaw
Lincoln, Nebraska
'91 Mazda Navajo
I haven't done the lift yet but have been looking into it for a couple weeks. From what I've heard and found out, you can order the spacers from your Ford dealership for around $30, and I emailed Warrior Products to find out where the nearest retailer was in my area: warprod@gte.net . I think they run about $50 shipped.
As for ease of install, so far I've read around 2 hours for the spacers and 15 minutes for the shackles. I'm not a mechanic, but from looking at my Navajo and my Haynes manual I don't think it will be more then an afternoon job with some friends and beer. Plus I'll be squeezing some 31x10.5s!
bigDerk
Stockbridge, GA
2001 Ranger Edge
The shackles cost me about $45 shipped from 4wheelparts, and the spacers were about $30 from Ford. The alignment ran me about $70 with adjustable camber bushings. So for the whole lift (minus the radius arm that I had replaced... stupid shock mount broke, GRRR) cost me about $150. Got 1.5" up front, 1.75" in the rear.
toad
Blue Point, Ontario, CANADA
2007 Sport Trac
Well mike i just posted a reply but the site cut me off, Oh well its no problem I piad in Canadian funds but the prices sound right. . I tried to say that i had trouble with the front stud and only got about 1/2 the nut on the stud after the spacers so I took a thicker nut and turned it down on the lathe at work about 1/2 way so the collar fit through the spacer ( some drilling required) lots of thread at least this way. Not all studs are short this way so try it first . got at least a 1 3/4 lift and it aligned O.K.
HAVE FUN EH ! TODD
