factory halogen to factory xenon problems
rickz07
Santo Domingo
2013 Explorer Limited
Hello,
I bought my 2013 explorer with factory halogens. I did not like the results from my hid converison kit upgrade so I opted to buy a pair of factory HID headlights thinking I could just swap them out. It isnt working. The turn signals work fine but the lights wont turn on.
Any ideas?
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
Anime
EF YEAH!!
2018 EX Sport Concept
Did you get the required OEM Ford igniters and ballasts to go along with the OEM HID housings or how do you have it hooked up?
If you have all the OEM parts but the lights just aren't turning on, I'd suspect a wiring issue, perhaps something simple like they just aren't getting power or the switch isn't connected correctly to turn the system on.
rickz07
Santo Domingo
The ballasts and igniters were included in the assemblies. I too suspect the problem is in the wiring. I looked in the fuse box and there are no fuses where the HID fuses should go. There also arent any contacts in those slots. I am guessing that the SUV units that ship out with Halogen lights are not equipped to handle HID lights. Can anyone confirm?
Anime
EF YEAH!!
You should find out what fuses need to go in those slots and put some in.
If the dealer doesn't know, perhaps someone on here with factory HIDs in their new Explorer could tell you.
cwescapexlt4x4
Explorin' the Desert SW
Litchfield Park, AZ area...
2016 Explorer LTD (FWD)
I used an aftermarket plug and play conversion without any issues. I guess the Ford OEM set up must not work the same and needs those said missing fuses.
C 2014 Ford Explorer Factory HID vs Halogen housing Performance Lighting 34
C Factory HID assembly Performance Lighting 1
S Factory HIDs seem pretty dull Performance Lighting 0
Eltee Tapping Auxiliary Lights Into Factory Fogs? Performance Lighting 9
X Strobe for factory lights??? Performance Lighting 16
J Need Help activating the factory fog lights! Performance Lighting 7
J Factory Wiring Performance Lighting 2
M Can you install factory fog lamps on explorer without exsisting fog lamps Performance Lighting 14
D Using the factory switch for off road lights Performance Lighting 3
R Bad factory leads? Performance Lighting 19
D Factory fog light switch and Bosch relay Performance Lighting 4
M Help with wiring on factory driving light switch Performance Lighting 7
F factory fog lights? Performance Lighting 7
B No factory foglights? heres the fix... Performance Lighting 5
B Installing Aftermarket Fog lights (in factory location) Performance Lighting 22
A Where To Order Factory Lamps (2004 EX) Performance Lighting 4
H 02-05 ex factory lighting question Performance Lighting 3
W Headlights with factory alarm... Performance Lighting 38
D Will Factory Electrical Support Lighting? Performance Lighting 7
m4dc0w PIAA 520's to factory fog lamp switch Performance Lighting 0
C factory fog lamp switch Performance Lighting 7
N Factory headlamps? Performance Lighting 3
Q factory fog lights Performance Lighting 2
justin146 H3 HID kit in 2000 factory fogs Performance Lighting 3
E factory keyless entry/alarm Performance Lighting 0
Z Factory Fog Light Wiring Diagram Performance Lighting 4
F Need Help With Replacing Foglight Bulbs (factory foglights) 2000 Explorer XLT Performance Lighting 1
T Factory Driving/Fog Lights help! Performance Lighting 1
D Real fast...factory light bulb? Performance Lighting 4
X Factory fog lights Performance Lighting 3
E HID, piaa pro90 factory integration- check this and help Performance Lighting 9
M Help me! Factory Fog replacement, $100 or less Performance Lighting 5
K Factory Strobe Light hole? Performance Lighting 2
P Wiring aftermarket foglights to factory wiring Performance Lighting 4
J Brighter Bulbs for factory fogs Performance Lighting 2
I 2002 X sport factory fog openening Performance Lighting 0
K Polarity on Factory Fogs? Performance Lighting 2
R factory foglamp bulb question Performance Lighting 2
B Wiring off-road lights to factory high beam switch? Performance Lighting 4
N Factory Fog lights Performance Lighting 4
E anyone have extra 91-94 air dam factory fog light mounts? Performance Lighting 0
B New fogs for factory opening Performance Lighting 0
Skunk Relocation of factory fogs Performance Lighting 1
Z Driving lights in factory opening- '01 Models Performance Lighting 1
P how do 99+ factory running lights install Performance Lighting 1
B Factory Fog Light Switch Question Performance Lighting 0
B Fog Lights With High Beams on w/ Factory Switch? Performance Lighting 15
B Lights that fit in factory bumper for 97? Performance Lighting 2
T No factory driving lights...what can I do? Performance Lighting 4
9 Will PIAA 60XT's fit in factory fog location? Performance Lighting 1
Similar threads
