Faded interior door panels
Joey Threesticks
Omaha
2007 Explorer Limited
Hey guys,
Just wondering if anybody else has experienced this or has any advice.
I have an '07 limited with the "camel" interior, and the plastics on my driver & passenger doors are sun faded at the top. They look a little chalky, like the UV from the sun has gotten to them over the years. Is there any way to restore these plastics without completely replacing them? That's farther than I'd like to go on a truck this age.
Thanks.
mhocken
Louisville, KY.
2001 Sport
Mine has faded the exact same way.
Explorer_PL
Rockland County, NY
06EB V8 & 07EB V6
Just did mine.
Took the door panels off, took them apart, bunch of 7 mm screws. Taped the lighter part with blue masking tape.
Bought LPV326 spray paint (Ford Camel) and spray them many times with a light coat.
Looks like new. The paint is about $ 30 a can on eBay. I was able to use one can for both doors.
07EddyB
Bowling Green, KY
2007 Ford Explorer 4.6 V8
Mine has the same issue. I read that heat would bring the color back so I pulled them and used a heat gun to 'bring' the color back to the top. That actually did work but I would not recommend it. For one thing, it left glossy spots where it took more heat and secondly it didn't last more than a few months. Been considering the paint approach myself.
C Faded running boards 07 Sport Trac Stock 2006 -2010 Explorers 0
D interior noises and driver side wind Stock 2006 -2010 Explorers 5
H Weird dimming of interior lights+slight brightening of headlights Stock 2006 -2010 Explorers 5
T 2006 cluster/interior lights dimmer switch ***SOLVED*** Stock 2006 -2010 Explorers 13
G 2010 Eddie Bauer Interior LED light replacement Stock 2006 -2010 Explorers 2
H Quiet down interior? Stock 2006 -2010 Explorers 31
F Interior Trim Code 4C. What color is this? Stock 2006 -2010 Explorers 3
M 2007 Eddie Bauer Interior Dye/Paint Stock 2006 -2010 Explorers 3
mgmgmg OEM INTERIOR AMBIENT LIGHTING KIT Stock 2006 -2010 Explorers 0
N Tailgate Interior Trim Removal Stock 2006 -2010 Explorers 5
E Repainting and armrest handle retrofit on 06 interior door panel. Stock 2006 -2010 Explorers 13
F interior lights wont come on Stock 2006 -2010 Explorers 16
B 4th Generation Interior Trim Pieces Stock 2006 -2010 Explorers 9
B Airbag Light After Interior Swap Stock 2006 -2010 Explorers 0
J Interior Light Replacement? Stock 2006 -2010 Explorers 2
B Interior Questions - Door Panels, Seats, Swapping ?'s Stock 2006 -2010 Explorers 5
B Are all 4th Gen interior door panels same size? Stock 2006 -2010 Explorers 12
Jacob Linder Updating Interior Dash Trim Stock 2006 -2010 Explorers 11
U Interior Light Problem Stock 2006 -2010 Explorers 1
D Haunted Interior Lights Stock 2006 -2010 Explorers 10
D 2007 camel interior color match Stock 2006 -2010 Explorers 12
M 06 Explorer Interior Lights Problem Stock 2006 -2010 Explorers 4
M Interior Liftgate Handle for 2006 XLT Stock 2006 -2010 Explorers 6
K Interior Lights Problem Stock 2006 -2010 Explorers 5
V 2006 Explorer interior lights won't turn on. Stock 2006 -2010 Explorers 3
N Help Please-Interior Lights coming on Stock 2006 -2010 Explorers 6
N interior bulb change - need help Stock 2006 -2010 Explorers 3
M 2007 Eddie Bauer interior Stock 2006 -2010 Explorers 2
2 Interior lights, auto shut off ? Stock 2006 -2010 Explorers 2
R Eddie Bauer Leather Interior Stock 2006 -2010 Explorers 5
R 2006 Explorer interior trim paint touch up Stock 2006 -2010 Explorers 6
N interior lights don't go on! Stock 2006 -2010 Explorers 23
V 2006 XLS - Liftgate Interior - Harness and trim question Stock 2006 -2010 Explorers 2
D rain water in interior cabin light switch Stock 2006 -2010 Explorers 2
M Driver Side door and interior lights Stock 2006 -2010 Explorers 11
N interior light problem...please help! Stock 2006 -2010 Explorers 1
C 2008 Explorer interior lights won't turn off Stock 2006 -2010 Explorers 2
N 2008 Explorer Eddie Bauer Edition Interior Trim Code ZC Stock 2006 -2010 Explorers 2
A What do you use to clean your interior? Stock 2006 -2010 Explorers 3
R Looking for interior spray for 06 explorer? Stock 2006 -2010 Explorers 1
V 2008 interior light problem Stock 2006 -2010 Explorers 8
M Interior Lights on '10 Explorer Eddie Bauer Stock 2006 -2010 Explorers 2
R Need help encoding interior paint before ordering part? Stock 2006 -2010 Explorers 2
R wheres the interior fuse panel located? Stock 2006 -2010 Explorers 0
S Interior Dome And Map Lights How To Open & Replace Stock 2006 -2010 Explorers 4
L 2008 Explorer interior lights turn on unexpectedly Stock 2006 -2010 Explorers 35
S 09 explorer dome interior lights question Stock 2006 -2010 Explorers 3
R need always on 12v wire near interior lights Stock 2006 -2010 Explorers 2
B Interior cargo panels Stock 2006 -2010 Explorers 3
H Interior Lights Stock 2006 -2010 Explorers 6
Similar threads
