DavidEBSmith
- January 26, 2004
- Chicago, IL
- '07 Mountaineer Premier
Lately, occasionally, on cold startup, my wife has noticed that the fan clutch on our Mountaineer engages with the accompanying roaring sound. It stays engaged for anywhere from 10 to 30 seconds, then disengages. It hasn't been hot enough around here that it engages any other time. The fan clutch has been replaced at least once, under warranty, so the current one has about 50-60K miles on it.
Since the noise really bothers my wife, I would just replace it, but for the cost, and that I found this: Rock Auto has fan clutches from Four Seasons, Hayden, and Motorcraft. On the Hayden page it says:
In searching old threads on the fan clutch, it looks like it pretty much never throws a code on our vehicles. And I looked in the Ford service manual and didn't see anything about the fan clutch engaging at startup.
So is it correct that the fan clutch on Explorers/Mountaineers will normally engage at startup - even cold startup? Or is sticking at startup a sign that the fan clutch is on its way out?
Electronic-Viscous Fan Clutch Troubleshooting During engine start up, the EV fan clutch will engage and match engine speed for up to 3 minutes. This is considered normal and may last more than 3 minutes in cooler climates or at lower driving speeds resulting in fan roar.
- Do NOT replace EV fan clutch unless a specific issue is identified by proper SI (Service Indicator / Check Engine) diagnosis.
- Do NOT replace an EV fan clutch for fan noise.
