muskogeezeke
- November 7, 2013
- Guthrie, OK
- 2002 Ford Explorer
Hey guys, obligatory newbie announcement.
EDIT: Sorry, guess you would like more info: 02 Explorer, 4.0, V6, 2WD
Used this form before many times. You guys rock, finally decided to register cause I got a problem I just cant figure out.
Car overheated and cracked the thermostat housing, causing alot of smoke.
Dealer said it was due to the coolant needed to be replaced, wanted $1100 to fix it.
Got it towed to my house. I replaced the thermostat housing, thermostat, gaskets and coolant temp sensor.
Started car, no leaks. However, even from a cold start, the fan kicks on automatically. I am not sure if it is cycling coolant. I got it to normal operating temperature, doesn't seem to get too hot once I get it to running temp, but has a slight burning smell when I turn the car off.
What do you think? My only guess is the pigtail that connects to the coolant temp sensor.
