rwaterhouse
- February 9, 2008
- Wetaskiwin, Alberta
- 91 Ranger 4x4
Hi;
I have a 91 Ranger, 4.0 L, 4X4, Auto with the following problem. It starts fine, idles fast for a few seconds and then goes to "normal" around 800 rpm. I then drive 20 miles to work, which is all hiway, and when I get there it is running high (1500 to 2000 rpm in park) and it is driving me crazy. Other than this the truck runs great. The CEL is not on ( I just bought a code reader of ebay and will scan codes when I get it).
Things I have tried:
Replace the IAC - no change. I got two from a pick n pull, neither makes a difference.
Pull the connector on the IAC - If I do that it immediately drops to 5 - 600 rpm, which suggests that the computer is TELLING it to idle that high, right?
Check for vacuum leaks - nothing obvious, and I'm puzzled what would leak only when the motor is hot.
Reset the computer - disconnected battery for 15min. No change.
Other information: This was intermittant, and seemed to happen more when it was cold out, but it has started the last couple of days doing it ALL the time.
I think I have read every post in here that refers to fast idle, but nothing seemed relevant. Suggestions welcome.
