Motorhogman
- February 22, 2018
- Location
- SC
- Hartsville, SC
- 2000 Ford Explorer Sport
UPDATE:
Note to self.. and others. When donalds makes a suggestion pay closer attention.
Installed the lower manifold.. Installed the upper manifold.. Thread stripped out on 3 of the wood screw holes at 40 inch lbs..
I assembled these manifolds on the bench and torqued to spec. 62 inch lbs.. Seemed solid. Must have been the last life those plastic holes had..
Picked up a new manifold.. $110.00 out the door. Came with $27.00 worth the seals already installed. I didn't use them. Used the new Fel Pro ones I bought.
All back together. Fired right up and still idling around the 1000 - 1100 rpm at operating temp..
Smoke test again.. Yep smoke puffing in paces that can hardly be seen, front of manifold below lower T stat housing.. Same place as before.
Disconnect the Evaporative Y tubing from the manifold and put vacuum caps on the ports.
Smoke test again.. NO sign of any smoke from any where.
In fact when I pulled the transfer pump hose off the power booster hose it blew smoke back out. It was pressurized
Start engine and let it run until up to temp with Y tube still disconnected and vacuum ports capped.
Idle comes down to that 650-700 rpm area..
Take it for a test drive. Runs good.. Made a few stops and starts.. Everything good.
Get back to the house put it in park and the idle is back up.. Not as high now, around 900 rpm now..
Going to look into using the BAFX OBII reader and the ForsScan Lite software I down loaded.
Learning is good.. LOL geeesh !
