Curious if there is interest in the following. Please let me know, if so I can start selling these soon.
Having trouble with your A4LD not shifting right? Want it to shift like it should without paying over $1000 for a rebuild by some shady transmission shop?
I can provide rebuilt and upgraded A4LD valve bodies (complete assemblies with solenoids) and all necessary new gaskets to install them, with instructions. Below is what I will do:
-Start with good 93/94 style valve body, separator plate included
-Cleaned, stripped down, ALL components checked and cleaned, including solenoids
-Transgo Shift Correction kit installed (recalibrated spool/valve springs, additional check balls as required, modified check pucks, modified separator plate, and more)
-New valve body gasket set included, upper and lower
-New reverse servo gasket and recalibration spring included with instructions
-Install any further upgrades you choose (see "Options" below)
This valve body will arrive at your door ready to install. New transmission fluid, a torque wrench and basic hand tools are all that would be needed for install. Full instructions will be included on performing the valve body swap. It could be completed in a day by a novice mechanic.
Pricing:
Valve body, complete rebuilt, with shift correction kit installed and all necessary seals/gaskets for installation - $200 shipped within US
Options (Ask me for advice on which are right for you):
Brand new solenoids for 3-4 shift and TCC lockup, installed - Add $40
Sonnax Boost Valve Kit, installed - Add $40
Sonnax Valve Body End Plug Kit, installed - Add $15
Sonnax High Radius Relief Valves, installed - Add $5
Sonnax 35mm governor weight, with instructions, you install - Add $10
Other Sonnax upgrades, as desired - ASK
New Wix brand transmission filter and pan gasket - Add $25
New Vacuum Modulator with installation instructions - Add $20
A core option may be offered to let you ship me your old valve body for a credit.
Any interest?
Pricing:
Any interest?
