CasterTroy
- December 14, 2004
- Kernersville, NC
- 2004 XLT Exp V8
So it only happens when going VERY slow, like backing out of the driveway, or first getting rolling in a parking lot.
Occationally (more often than not now) when backing very slow, and usually turning the wheel slightly, I get a sensation thru the steering wheel and pedal of a vibration. It feels sort of like when I had 36" TSL's on my Bronco and it only had a 6" lift. When I'd lock the steering and turn the big lugs of that tire would rub on the fenderwell at the firewall. It FEELS like a small variation of that WITHOUT the sound of tire rub.
It occures mostly when the wheel is slightly turned, I can say I recall it happening when the wheel is ever straight, and it never occurs once over 3-4mph
Should I be looking at the rear end for this issue? or Tranny?
2004 V8 95k AWD
Tranny's not been serviced since about 24k
Had rearend issues around 35k. It had a POP when you cut it to the right. Dealer "fixed" it.
Rear end had "whined" since then. Said it was not an issue other than sound.
2004 V8 95k AWD
