cclay6482
- June 16, 2002
- Tulsa, Oklahoma
- 96 xlt
Need some advice. I am in the process of replacing a timing cover gasket that had a slow coolant leak. Engine is the 5.0 liter, 2001 awd. I dropped the oil pan to provide the necessary clearance to get the cover off. I am using the Felpro 45450 gasket kit to put everything back together again. Neither my kit, nor another sealed kit at the parts store had any instructions in the box, and I am unsure whether I need to cut and remove the front of the oil pan gasket or not. Pretty sure it needs to be out of the way, and the cork corners replace it, but I wanted to make sure I needed to do this before I started. Thanks for any help or advice....
