Filler on plastic?
briwayjones
Manual Master
Location
Maryland, USA
Eldersburg, MD
2000 Ford Explorer XLS
What would I use as filler for the same purpose as bondo on body work but for the plastic case of a computer monitor? I don't think bondo would work because I don't know if it would stick to plastic and the plastic would flex too much for bondo to work without cracking. Would fiberglass resin work? I need something that's paintable. Other than fiberglass resin I don't have any ideas. Does anyone else?
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
Yeah resin will work. Or if you want to add strands of fiberglass, that'll work too. There are some plastics that are very difficult to bond to - like delrin/acetal, but computer monitors are probably not made from delrin. As with any resin work, prep is important so sand the surface with maybe some fine grit paper, then wipe clean with rubbing alcohol.
Paraphoe
Go big or go home
Willow Grove, PA
'97 XLT
Is there anything you DON'T know? :confused:
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL Pumpkin Edition
Callsign
AB7FH
Plenty, like how to swim - I've almost drowned twice, both in the ocean :thumbdwn:.
If you don't know how to swim, I would start in a smaller pool;):p:
