Finally got the money to lower my truck, need some advice now
Afboy143
Tampa,FL
1999 Ford Explorer Sport
Well last christmas I got 2" blocks for the rear thinking thats all I needed to lower my truck but after doing more research I was wrong. Well now I have the money for the shocks, adjustment, and camber adjusters. I want to drop the rear 2 inches since its already lower 1" stock for a total of 3" and take the bolts all the way out in the front which will hopefull drop 3" Also. I know I will need new shocks but I dont know which kind to get or where to get them. I want to try and not go over 150$ Also I know I need to shave my bump stops but how much? So blocks for the rear, take bolts all the way out in the front and get camber adjusters and alignment, then all new shocks. Sounds good right? Now where do I buy these shocks?
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
X~FACTOR
Name is Ray
Valley Stream, Long Island
'97 XLT 4-dr SOHC
Shocks under $150? Gabriel VST for about $100. You install them.
Where? Pep Boys or any large auto parts store in your area.
Bump Stop? I took 1/3 off. Seems to be enough in my case with just 2.25 drop.
Lower the front first before deciding what to do in the back. You don't want to end up with the truck tilting up.
Afboy143
Tampa,FL
well how good are these shocks? I dont wanna end up with some crappy shocks...
XplorerKid
Rolling on 37"s
Winter Haven Fl
1997 Xplorer
Go buy the old saying, "you get what you pay for"..... figure the Gabrials go for 20$/ea i guess, ide try some Rancho 5ks or something else, but i guess is money is tight the gabriels are fine, Dotn get me wrong from what i read these Gabriels are woudners over stock so they should do fine, they just may wear out a little quicker
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
I don't think your shocks will make to much of a difference. These trucks ride hard, and lowering them makes it all that much worse.
draft
Los Angeles, CA
Mounty Sport
Without buying lowering shocks, the ride will suffer anyways that much more, as well as wear them alot faster.
Afboy143
Tampa,FL
well I called pep boys about those gabriels and they dont stock that company nemore, just menroe. Does anyone have ne more ideas on shocks under 150? I really want to get my truck lowered!
Mbrooks420
High Voltage.
EF Vendor
Rancho's make a good product, and will be te next shocks on my truck. I believe you can get the Explorer shocks in a slightly shorter version from them. I'd call a suspension place, or somewhere that isn't a factory replacement place like autozone, pepboys, ect.
