Find out what gear ratio you have...
jordansypek
New Britain, CT
01 Limited 5.0 AWD
I know a few of your are probably scratching your heads. I am a newer member on this forum, and after using the search feature I couldn't find anything that had some sort of chart for Gear Ratio codes and their Gear ratios. I am going to start a post and maybe it can be moved into the Useful Threads area....If there is already one on here, excuse me for repeating....
The Axle code can be found on the label on the inside of your driver's side door.
41 - 3.27 non-limited slip (Explorer/Mountaineer)
45 - 3.55 non-limited slip (Explorer/Mountaineer)
46 - 3.73 non-limited slip (Explorer/Mountaineer)
42 - 4.10 non-limited slip (Explorer/Mountaineer)
D1 - 3.27 limited slip (Explorer/Mountaineer)
D4 - 3.73 limited slip (Explorer/Mountaineer)
D2 - 4.10 limited slip (Explorer/Mountaineer)
If anyone notices my data is wrong, or anything has been left out, please let me know.
XplorerKid
Rolling on 37"s
Winter Haven Fl
1997 Xplorer
this is a VERY good chart.. there was oen already on here .... btu maybe the new memebrs will see this one instead
PEACE:)
fastcougar
Kearnysville, WV
02' Mountaineer - V8 AWD
Yeah, where do you find the code? ;)
bluestang65
lees summit, missouri
96 explorer sport
jordansypek
New Britain, CT
01 Limited 5.0 AWD
guess this isn't considered useful information....
MONMIX
I fix dents
Staff member
Moderator
Millersville , Maryland
2000 Explorer Sport
I found it useful.
Thank you very much
Ray Lobato
Moderator
Moderator Emeritus
2006 Honda Accord
Actually if you check the very first post on the "Useful Threads" Forum, there is a post about Ntrprize's webpage. It has all the information on axle codes, VIN information and a lot of other year specific information about the Explorer. It is very comprehensive.
pohonasin
Bogota, NJ
1996 xlt
OK, I know what gear ratio I have, but what does that mean exactly? My sticker says "D4" 3.73 Limited slip. I have a AWD V-8. Is this a good thing, good torque, "Strong Like Bull"! or just so so. After all, its only an Explorer, not a F350.:eek:
XLT_Explorer
thunder bay ontario
95 XLT
this sucks i got 3.55's no 31's for me
bmxking5
Monroe, GA
'93 Sport & '96 XLT
What are you talking about??? I have 3.27s and 31s, and the power is almost the same as before(with no more performance mods). One guy is currently running 3.55s and 35s :eek: You'll be fine with 31s.
RedEB
Portland, OR
97 XLT
What are you talking about??? I have 3.27s and 31s, and the power is almost the same as before(with no more performance mods). One guy is currently running 3.55s and 35s You'll be fine with 31s.
I noticed a decrease in performance and economy when I went to 31's and I have 3.55s. I went from an average 21 mpg to about 16-17 mpg and my performance isn't nearly as good as it has been. I have noticed that sometimes when I start my car after it has been sitting maybe an hour or two after opertaion, when I shift into drive my car will stall and I will have to start it right back up. Maybe that is my problem... Should I notice such a decrease in performance/economy?
metstalker
Atl, Georgia
94 Ford Explorer XLT
umm you forgot the unfortunate people with 3.08 ratio like me
metstalker
Atl, Georgia
thats great i have 3.08 and was averageing around 20 mpg but now i get a whopping 10 with 31s and no accleration at all. but not to worry im installing 3.73 after spring break
XLT_Explorer
thunder bay ontario
95 XLT
i just don't need to put any undo stress on the garbage tranny the ford the A4LD.
RedEB
Portland, OR
97 XLT
Sweet! How much will that all cost by the time it is all said and done? Where did you buy the gears from? I am thinking about doing the 3.73 swap as well, I just need that extra oomph!!
metstalker
Atl, Georgia
proably around 500 dollars i bought the gears from leetz off this site and the install kit cost me 90 dollars gears 50 + shipping = 70 dollars and the install itself will be 350 with cost of fluid so not a cheap investment by far but ive finally put everything together and will soon be doing it
TheRookie
Traveling SAS guru
West Chester PA
91 explorer xlt
That sounds like only one axle. You have a 2wd?
metstalker
Atl, Georgia
yep
ions
Pasadena, MD / Annapolis , MD
'01 Explorer Sport Trac
w000 i got 4.10 :thumbsup: i guess this is a good thing.
