Finished 2 inch Body lift!
GRNMACHINE
IL
95 Sport 4x4
i have a ttt and shackles and im running 33s just fine with no cut but im doing the body lift soon and will be able to run 35s with a lil cutting i think
I would like to see pics of running 33's with only tt and shackles. 33x10.50 wouldnt clear normally with only that amount of lift.
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
fordkevin
Gladstone oregon
1997 ford explorer xlt
im running 33 buy 12.5 on mine with just a tt and shakles no rub and anyword on the
BackBone
Redlands, CA
1997 Mercury Mountaineer
Summit racing carries 2" bodylift blocks.
I'm having a hard time finding a 2" BL kit for my 2000 Explorer Sport. Which kit did you use and do you think that it would be the same for my truck? I'm able to find the 3" kits no problem, I just don't feel like messing around with steering or shifter extensions.
As a side note, some of the kits say that the shifter extension is required. Does anyone know if it needs to be welded? Can I make due without it and just deal with a shifter that is 2" shorter?
2"X3" body lift blocks at Summit Racing (performance accesories brand)
http://www.summitracing.com/parts/pra-bb02/overview/
GRNMACHINE
IL
95 Sport 4x4
link isnt working
longski325
2001 ford explorer sport
lift details
How many spacers/mounts are there with the kit? Is there any online guides for doing this?
clevalley
Warrenton, VA
2000 Explorer XLS
There are 8 total spacers you will need.
I just did a 3" lift - http://www.explorerforum.com/forums/showthread.php?t=419615 - 9th post down in this thread I used the bolt length from a post somewhere here in the forum, but you will have to convert mm to inch, and subtract 1" from the bolt size I list (since I did a 3" lift and you want to do a 2")
traveler
Staff member
Moderator
Location
Mesa AZ
Mesa
2000 EB Explorer 5.0
I've been doing research... I am planning on a 2" body lift. In the interest of helping others I did the math. If anyone finds an error please feel free to let me know. I couldn't find anyplace that said how long the factory numbers are, but could find how long the 3" lift kit bolts are. Based on that, I did the math to find the lengths for the 2" and stock heights. The Numbers for the MM are accurate, the Inches are rounded. For the mounts under the rear of the front seats, I took the given length of the 3" lift rear cargo area bolts, then subtracted 3". This gave me the stock length of the rear of the front seat bolts. Then used that info for the stock and 2" lift bolts. Again, if I did anything wrong, let me know.
Body Mount Bolts Stock
Front mounts - 105MM = 4”
Mounts that are in front of the front seats - 65MM = 2.5”
Mounts just under the rear of the front seats - 50MM = 2”
Mounts in the front of cargo area - 85MM = 3.5”
Mounts in rear of cargo area - 125MM = 5”
Body Mount Bolts 2” lift
Front mounts - 155MM = 6”
Mounts that are in front of the front seats - 115MM = 4.5”
Mounts just under the rear of the front seats – 100MM = 4”.
Mounts in the front of cargo area - 135MM = 5.25”
Mounts in rear of cargo area - 175MM = 6.75”
Body Mount bolts 3” lift
Front mounts - 180MM = 7”
Mounts that are in front of the front seats - 140MM = 5.5”
Mounts just under the rear of the front seats – 125mm 5" (or stock bolts from the very rear mounts)
Mounts in the front of cargo area - 160MM = 6.25”
Mounts in rear of cargo area - 200MM = 8”
Edited 4/2/2020 for accuracy. If you'd like to figure your own lengths, 1" = 25.4mm
Afrojoe1449
Ringgold, Georgia
1998 Ford Explorer XL 4WD
Just to 100% verify before I go and buy 2 inch pucks. I need 10 pucks or 8? There's nothing to relocate with a 2 inch body lift other than the fan shroud and possibly bumpers? Not the e-brake, fuel filler neck, or electrical connections? I'm mainly worried about having to do a steering extension like with the 3 inch. So far 2 is seeming much easier and would fit my needs great. I'd like to leave the radiator mounted to the body and just drop the shroud to help keep the radiator higher up (better approach angle and safety).
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
You guys just order a 3" body lift kit and cut the pucks down to 2"
Afrojoe1449
Ringgold, Georgia
PA883 is like 200 dollars now and I was able to find 2 inch pucks for 60 dollars shipped. So I figured it'd be easier to find bolts than it would be to cut 3 inch pucks.
traveler
Staff member
Moderator
Location
Mesa AZ
Mesa
In case anyone comes across this thread, and wonders where to get the bolts at, I just ordered a set from a website called "Bolt Depot". Easy to order from, prices were... fair. I got 10 Grade 8 bolts and nuts shipped for roughly 40 bucks. Also got washers.
S finished 2"body lift Shocks, Suspensions, Lift Kits 22
T Finally.. X is finished, for now. Shocks, Suspensions, Lift Kits 3
B just finished a lift Shocks, Suspensions, Lift Kits 14
S finished my 3" BL...almost Shocks, Suspensions, Lift Kits 36
V Finished my AAL Shocks, Suspensions, Lift Kits 7
F finished install on body lift 883 just have a few concerns? Shocks, Suspensions, Lift Kits 10
C finished soa with zimm. springs Shocks, Suspensions, Lift Kits 0
D Finished the lift, but Shocks, Suspensions, Lift Kits 8
0 Just Finished torsion on 00 Sport Shocks, Suspensions, Lift Kits 4
P just finished my lift (2:30am) Shocks, Suspensions, Lift Kits 6
M 2.25 inch t bar key's Shocks, Suspensions, Lift Kits 0
9 Fitting 32 inch tires with only 1-2inch suspension lift Shocks, Suspensions, Lift Kits 0
N Anyone have pics of 2 inch lifted explorer with 31 inch tires? Shocks, Suspensions, Lift Kits 15
K Do I need a longer rear drive shaft, After 4 inch lift on a sport Shocks, Suspensions, Lift Kits 7
L 3 inch body lift and TT/Shackles. Shocks, Suspensions, Lift Kits 6
J +3 inch leafs? Shocks, Suspensions, Lift Kits 2
T 2 inch Body Lift Questions Shocks, Suspensions, Lift Kits 7
E 4 inch lift. Shocks, Suspensions, Lift Kits 2
T Where can I buy 1 inch body lift pucks? Shocks, Suspensions, Lift Kits 7
Blee1099 95-01 Bumper Brackets for 3 Inch Body Lift Shocks, Suspensions, Lift Kits 0
S 4 inch lift, 92 eddie bauer 4x4 Shocks, Suspensions, Lift Kits 3
R Around 80$ 4 inch lift Shocks, Suspensions, Lift Kits 4
loner4u69 8 inch lift for 1991 - 1994 explorer Shocks, Suspensions, Lift Kits 5
W Superlift 5.5 inch lift kit for 92 explorer Shocks, Suspensions, Lift Kits 7
E 4 inch lift Shocks, Suspensions, Lift Kits 1
C 01 Sport Rear-End is offset by 1-inch Shocks, Suspensions, Lift Kits 1
B 3 inch body lift needs Shocks, Suspensions, Lift Kits 1
J camburg 6.0 kit for front or 4 inch TT with cam kit installed Shocks, Suspensions, Lift Kits 6
D 33's on 3 inch lift Shocks, Suspensions, Lift Kits 16
M cheapest 4 inch lift Shocks, Suspensions, Lift Kits 11
H 6 inch lift for 2nd gen Shocks, Suspensions, Lift Kits 11
M need a cheap 2-3 inch lift kit Shocks, Suspensions, Lift Kits 10
A Trailer Hitch With 2 inch body lift?? Shocks, Suspensions, Lift Kits 5
M '03-'04 2 inch lift Shocks, Suspensions, Lift Kits 9
H 3 inch body lift 99 Shocks, Suspensions, Lift Kits 3
I Lowering an inch Shocks, Suspensions, Lift Kits 8
C 2 inch susp lift Shocks, Suspensions, Lift Kits 2
L Offroad tires with 20 inch rims Shocks, Suspensions, Lift Kits 6
F steering exstension? 2 inch B\L 98X sport Shocks, Suspensions, Lift Kits 13
E 2.5 inch lift Shocks, Suspensions, Lift Kits 3
9 3 Inch Body Lift Shocks, Suspensions, Lift Kits 2
B 3 inch body lift Shocks, Suspensions, Lift Kits 5
J 6'' drop brackets 5.5 inch coils? Shocks, Suspensions, Lift Kits 2
4 1st Gen Explorer with an 18 inch lift Shocks, Suspensions, Lift Kits 1
9 What shocks do you run on a 2 inch Daystar lift Shocks, Suspensions, Lift Kits 1
S 2/3 inch body lift for 02 Explorer!?! Shocks, Suspensions, Lift Kits 4
F 4 inch and 5.5 inch spring measurements for superlift Shocks, Suspensions, Lift Kits 1
F need to see 02 explorer with 3 inch lift.....i want to lift Shocks, Suspensions, Lift Kits 4
I 3 Inch Body Lift (Ranger Kit) on 95 Explorer Shocks, Suspensions, Lift Kits 4
JTX 94 Explorer with 10.5 inch's of lift! Shocks, Suspensions, Lift Kits 22
Similar threads
