Brian1
- February 2, 2000
- Albuquerque, NM
- 1991 XLT
- Callsign
- KG5BAQ
Well I think this fits here in offroad fabrication more than tires/wheels forum. I just finished up building a set of recentered hummer beadlock rims for my crawler. Im not going to go too in-depth about the build because the wheel buildup will be featured in a 4x4 magazine tech article in the future.
I went with hummer wheels because I needed a beadlock for my 16.5" rim size tire which are known for loosing beads easily. The stock hummer wheels have about 7" of stock backspacing which is excessive and will not clear many steering setups including mine. I bought new pressed centers from USA6x6 with my 8 lug pattern. You can get them in others as well.
Started by cutting out the stock center with a plasma. Next was placing the wheel on a jig to weld the new center in. This is the important part so the wheels run true. 0.030" is supposedly the industry standard for wheel runout. The center was tacked then bolted on to my rear axle and rotated with an indicator. Then they got welded up.
Next the rock rings got welded on the outer shell. This is to reinforce the wheel lip which is flimsy on the 8 bolt wheels. The ring is 1/4" and is from Ballistic Fabrication. The cut outs around the outside allow for mud to be washed out.
The beadlock is a newer design from 66CJDean at Performance Cryogenics. It is basically a cage that gets welded together and put inside the tire which locks both beads in place. I put a tack on each joint to make sure they dont come apart, shown where the pieces of tape are.
The 2 wheel halves bolt together making tire mounting very easy.
