First Gen Front Differential Fluid | Ford Explorer - Ford Ranger Forums - Serious Explorations
offroadtuba
Morgantown, WV
'92 XLT
I really haven't been able to find a definitive answer on the forum. What type of fluid goes into the front differential on a first gen (specifically 1992) Explorer? The manual just says "4x4 gear oil" as does the computer at Advance Auto.
I just want to be sure exactly what to put in before I screw something up. I just need to top it off. It's low after I leaked some out when I took out the driver's side axle.
Thanks
FIND
Vermillion, SD
99 XLT V8 AWD
I use 75w90, but I guess the weight isn't that important, since it is not like you drive much or far with the 4wd on.
