First oil change for my explorer | Ford Explorer - Ford Ranger Forums - Serious Explorations
Russell707
2015 Explorer limited
hello guys. I bought my explorer limited about 2 months ago. It’s come to that time for a oil change. I have the 2.0 ecoboost. Can you guys help me with which oil do I need and how many quarts? Thanks guys
Mbrooks420
High Voltage.
1998 Mountaineer AWD
5w30, 5.7 quarts with filter. I’d go full synthetic of whatever is on sale, and a Motorcraft, or Wix filter.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum Russell.:wave:
All that info is available in your Owner's Manual. I suggest that you read through it as it has a lot of info in it. More than a person can absorb in one reading. You can also download a copy; 2015 Ford Explorer Owner Manuals & Warranties | Official Ford Owner Site
I'm guessing that you are in the U.S. Canadian Explorers come with regular premium (non synthetic) as a recommended oil. That's all I've used in my vehicles but a synthetic blend of a full synthetic surely won't hurt.
Mbrooks420
High Voltage.
For as often as I change oil I don’t see that much benefit. It takes a single wrench to change, and I don’t need the extra risk of something hanging out of my oil pan.
bigdude2468
2014 Explorer XT
As long as you use a major brand oil in the correct basis weight you will be fine. Synthetic, semi synthetic or conventional oil will provide the necessary protection. There is little evidence other than anecdotal that synthetic is better. I use Mobil 1, pick it up when it is on sale at Costco or Walmart has a five quart jug for under $23, that's only $10 more than conventional. I change oil in my Explorer twice a year so for $20 why not.
JAPeterson
Gypsum, Co
2016 XLT
Anyone use one of these?
https://www.amazon.com/dp/B003VCD7U...colid=DHG4S5SEBLH6&psc=0&ref_=lv_ov_lig_dp_it
I have it on my current car and it makes oil changes so much easier. It doesn't leak, and it sits above a frame crossmember so it isn't exposed and can't be torn off.
Saves having to dig the bolt out of the oil change box :)
I have been running one on my Ford diesel for over 160,000 miles and over rougher country than the Explorer will ever see with zero problems. If you are worried about it hanging down to low remember that the Explorers drain plug comes out of the back of the pan and not from the bottom. The nicer thing about the Fumoto Valve is that with the hose nipple you can direct it directly into a bottle to catch the oil instead of having it shoot backwards and get all over the transmission mounts.
chartquist
Memphis, TN
2016 Explorer Sport
