First start of the day
slowtruggy
lumberton tx
1994 explorer
My 94 explorer The first start of the day it just turns over won't start if i spray throttle body cleaner in throttle body it starts right up I changed the throttle body sensor but still does it any ideas thanks
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
natenkiki2004
Blue Bomb!
Location
North Idaho
1991 & 1994 Explorers
I know the feels. Does it fire right up if you feather the throttle while cranking? Mine did that every single time but only does it occasionally after changing the injectors. I hate to say that 'fixed' it. I'm kind of leaning towards the IAC since I keep getting a KOER for it but it idles fine, even under load (heavy steering while parked, etc) and I've cleaned it.
Start simple; test the ECT & IAT sensors, replace if faulty.
funfool
Albuquerque New Mexico
1998 sport explorer
Have you checked the fuel pressure at the rail?
Almost sounds like the fuel pump is going bad and losing prime.
natenkiki2004
Blue Bomb!
Location
North Idaho
If that's the case, cycling the key from OFF to RUN and back a few times should fix the issue (mask it, actually).
slowtruggy
lumberton tx
1994 explorer
Thanks everyone it was the temperature control sensor
natenkiki2004
Blue Bomb!
Location
North Idaho
natenkiki2004
Blue Bomb!
Location
North Idaho
Sweet deal, that's a cheap fix :) Glad you got it sorted out.
L Low Idle Speed and Cold Start Stalls Stock 1991 - 1994 Explorers 4
A Dying right after start up? Weird issue, totally stumped. Videos Stock 1991 - 1994 Explorers 8
B 93 Explorer won’t start with key Stock 1991 - 1994 Explorers 4
L Low Idle and Stall at Start Stock 1991 - 1994 Explorers 2
N *FIXED Crank no start after replacing crankshaft pulley. Stock 1991 - 1994 Explorers 13
O Cold Start problem Stock 1991 - 1994 Explorers 10
C Remote Start Questions Stock 1991 - 1994 Explorers 4
9 Ran great. Went out to dinner. Won't start ?? Stock 1991 - 1994 Explorers 8
P Cranks no start Stock 1991 - 1994 Explorers 3
K 1993 ranger won't start Stock 1991 - 1994 Explorers 1
T 94 every now and then will turn over and not start Stock 1991 - 1994 Explorers 5
D won't start Stock 1991 - 1994 Explorers 4
W I just bought a 1994 Explorer, and it won't start. Stock 1991 - 1994 Explorers 6
R 93 Explorer Crank, no start Stock 1991 - 1994 Explorers 12
C 1992 Explorer Fuel Pump Staying On, No Start Stock 1991 - 1994 Explorers 0
L 1993 4.0 No Start Stock 1991 - 1994 Explorers 36
J Help! No start, fuel pump constantly running Stock 1991 - 1994 Explorers 3
B My 94 Won't start Stock 1991 - 1994 Explorers 7
C 1992 Explorer XL wont start Stock 1991 - 1994 Explorers 2
C 1994 explorer v6 4.0l XLT new fuel pump, won't start. Security system, ecu? Stock 1991 - 1994 Explorers 2
D 93 Explorer dies and won't start again for minutes after a hard stop or turn Stock 1991 - 1994 Explorers 18
C First hesitation, rough idle, then no start... Stock 1991 - 1994 Explorers 4
A Awful Grinding Sound with No Start Stock 1991 - 1994 Explorers 13
M Start working on it' Stock 1991 - 1994 Explorers 13
K Hard start cold and almost stalls putting the clutch in for a stop. Stock 1991 - 1994 Explorers 8
D 93 explorer won't start not getting fuel. Need advice please! Stock 1991 - 1994 Explorers 1
E Died will not start back up Stock 1991 - 1994 Explorers 10
L '94 4x4 button on dash does nothing, where to start? Stock 1991 - 1994 Explorers 3
M 93 ex won't start replaced almost all components Stock 1991 - 1994 Explorers 5
N 94 Explorer wont start after changing Crankshaft position sensor Stock 1991 - 1994 Explorers 7
T Stump the chump, round two. Rough start... Stock 1991 - 1994 Explorers 14
mr cribb no power, no start Stock 1991 - 1994 Explorers 22
B 1994 XLT - Wants to die on first start of the day Stock 1991 - 1994 Explorers 2
M 1991 Ranger with 4.0 swap No Start Stock 1991 - 1994 Explorers 34
P crank no cold start Stock 1991 - 1994 Explorers 19
S *FIXED! Thx Number4." Changed clutch on my '94, now the engine won't start. O.o Stock 1991 - 1994 Explorers 9
L Hard cold start bad gas mileage Stock 1991 - 1994 Explorers 20
C 94 no start Stock 1991 - 1994 Explorers 6
K Rough idle on cold start Stock 1991 - 1994 Explorers 17
M Dieseling - bad fuel smell - smoke - fast start Stock 1991 - 1994 Explorers 1
D 94 explorer died ,wont start Stock 1991 - 1994 Explorers 19
D 94' sounding very bad at start, still not so great after Stock 1991 - 1994 Explorers 6
A turns over but wont start Stock 1991 - 1994 Explorers 3
O Ford Explorer No Start!!! Get only a single "click" Stock 1991 - 1994 Explorers 13
T 1989 Ford Ranger won't start. Stock 1991 - 1994 Explorers 1
ld50 Engine dies, won't start, then starts. Stock 1991 - 1994 Explorers 5
G Engine won't start - fuel supply issue suspected Stock 1991 - 1994 Explorers 5
A Before I start working on it AGAIN... Stock 1991 - 1994 Explorers 1
K No start Stock 1991 - 1994 Explorers 6
M poor gas mileage/rough idle on start/lose power after warming up Stock 1991 - 1994 Explorers 21
Similar threads
