First time 4WD use this morning
digifoss
Grants, NM
07 Explorer XLT
After owning this Explorer for two months now and having not had a chance to try out the 4WD, this morning brought 6 inches of snow, single digit temperatures and extreme icy roads - a great morning to get a feel for the Explorers 4WD. It couldn't have worked any better. I have a steep drive way, exiting is all uphill and it was all nice and slick this morning so I used the 4Low out of my place and down to the first stop at about 20mph, then switched to 4Hi to run my errands, all worked great. I notice a little single thump when going in or out of 4Low. while stopped, in neutral with the brake pedal pressed. It sounds like something normal, hope it is but it works great. 4Hi is really all thats necessary so I don't see 4Low getting used much. Going in or out of 4Hi while moving is undetectable except for the "4x4" LED that lights up or goes off in the dash panel.
Explorer_PL
Rockland County, NY
06EB V8
I'd use 4HI, and stay in 4 Auto. 4LO is for really bad conditions and strains the drive train.
In 12 years I have had mine, I use 4Lo just few times.
michael loibl
maywood, new jersey
2006 eddie bauer
I finally used 4 low for the first time after 12 years of ownership this past October
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
Even if you don’t use it, I’d exercise the shift motor at least twice a year.
digifoss
Grants, NM
07 Explorer XLT
All useful answers, thanks for the replies. My 95 Suburban also has 4Hi and 4Lo. I have used the 4Lo once that I can remember in 12 years. As for the Explorer, having 4Lo is a nice option if there was ever any need for it. I only used it yesterday because I wanted to know whether it worked or not. Going forward, the only use 4Lo will probably get is to engage it once in a while to keep it in working order as Mr Brooks said.
AKForce
09 Explorer 4.0
One thing that I have noticed living in Alaska is that 4lo is great for super snowy situations where traction or passability is extremely limited, but it seems to take a real strain on the entire system even if used sparingly.
We use 4lo 3-4 times a year during the winter and the drivetrain and especially front wheel setups always seem extra stressed from 4lo.
Mbrooks420
High Voltage.
EF Vendor
If there is plenty of slip 4 Low shouldn’t really cause any real stress over 4wd HIGH. It’s also much easier on the transmission.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
4Lo is less stressful on the engine and trans, it multiplies the torque by what, 2.5 times. It's also a good way to test the rev limiter if the trans will shift that high. Make a good video too wouldn't it, show the tach climb really quick, do it on ice and the speed would too.
I hope I haven't given anyone any bad ideas.:eek:
B 2006 4wd sytem problems Stock 2006 -2010 Explorers 0
L 06 Explorer 4WD 4.0 sohc question about ballance shaft Stock 2006 -2010 Explorers 10
J 2008 Explorer 4WD-Latest year engine I can substitute? Stock 2006 -2010 Explorers 7
T 2008 Explorer 4wd Differential vent hose Stock 2006 -2010 Explorers 2
D 06 Explorer V8 4WD the cooling fan constantly runs high Stock 2006 -2010 Explorers 2
1 Opinion on AWD vs. 4WD? Stock 2006 -2010 Explorers 6
Z 4L 4wd Struts and end links...what do I need? Stock 2006 -2010 Explorers 7
G 2010 4WD - Service Intervals diffs and transfer case Stock 2006 -2010 Explorers 10
G Proud Owner of a 2010 EB 4WD V8 Stock 2006 -2010 Explorers 2
G Niece wants a 4WD Stock 2006 -2010 Explorers 15
G In the market for V8 EB 4WD (AWD) need pointers Stock 2006 -2010 Explorers 16
B Can you plow 2 foot deep snow with a V6 explorer 4wd? Stock 2006 -2010 Explorers 9
R 06 Eddie B 4.0 4WD Ticking at Idle Stock 2006 -2010 Explorers 1
B Auto 4WD & 4x4 Not Working Stock 2006 -2010 Explorers 3
Y IWE solenoid? (4wd actuator) part number Stock 2006 -2010 Explorers 2
P 2008 Explorer XLT 4WD Rocker Moulding Options Stock 2006 -2010 Explorers 1
W What Sensor(s) should I change? 2010 Eddie Bauer Edition V6 4WD Stock 2006 -2010 Explorers 0
H 2007 Ford Explorer 4.0L Eddie Bauer 4wd Rough Idle / Surge at highway speed Stock 2006 -2010 Explorers 3
N please help - 2010 exp EB 4wd and turning problems Stock 2006 -2010 Explorers 9
Y 2006 4x4 rubbing noise in 4wd Stock 2006 -2010 Explorers 1
B Replacing just two tires on a 4WD? Stock 2006 -2010 Explorers 13
S 2006 Exp XLT 4.0 4WD - Suspension Input Stock 2006 -2010 Explorers 1
Y 4WD loud popping and thumping feeling Stock 2006 -2010 Explorers 1
U 2006 Explorer Limited V8 4WD Questions from new owner Stock 2006 -2010 Explorers 1
9 6r60 2wd vs 4wd compatibility Stock 2006 -2010 Explorers 5
G 2007 Explorer - 4wd and traction control engages with turns Stock 2006 -2010 Explorers 5
B 2007 Explorer Eddie Bauer 4wd question Stock 2006 -2010 Explorers 1
J 2008 explore 4wd front passenger cv half shaft HELPP!!! Stock 2006 -2010 Explorers 9
E Need engine removal instructions for 2006 v8, 4wd Stock 2006 -2010 Explorers 3
R Is it possible to install a Shelby engine with a 4wd system? Stock 2006 -2010 Explorers 23
O 2006 Explorer V8 4WD Gas Mileage Woes Stock 2006 -2010 Explorers 19
R 08 wheel hop / 4wd auto engaging Stock 2006 -2010 Explorers 0
E Did they make a V8 2010 limited fully loaded 4wd? Stock 2006 -2010 Explorers 8
SnTx4 Auto 4wd question Stock 2006 -2010 Explorers 3
R 2007 4WD Front Wheel Bearing Stock 2006 -2010 Explorers 4
E 2007 Explorer 4WD with 100k Stock 2006 -2010 Explorers 4
S Tires 2006 4WD XLT Stock 2006 -2010 Explorers 2
D 4wd low issue Stock 2006 -2010 Explorers 11
T HOW TO: 2006 Explorer V8 4WD Rear Strut Change Stock 2006 -2010 Explorers 22
A Inquiry about New Explorer XLT 4WD Stock 2006 -2010 Explorers 5
B 4wd Or Awd Stock 2006 -2010 Explorers 3
J please help p0304 and p0316 only after 1st time start in the morning Stock 2006 -2010 Explorers 9
Similar threads
