Schnitzel
- April 9, 2020
- Fort Collins
- 1997 XL 4wd
Hey guys I absolutely love my 96 manual explorer and have done a ton of work to it this year and would love to keep it. Since I bought the truck 6 years ago I've always had a hard time shifting into 1st especially when it's cold or hasn't been driven for a bit. Lately my other gears especially 2nd were getting really hard to shift into. I took it to a shop and they "Suspect shift forks worn and pressure plate is starting to collapse" and want $4,000 to replace the transmission with a used one. They also wanted to replace the clutch and slave cylinder but those should be good as I replaced them in 2019 and barely have 4k miles on them. They topped off the trans fluid and it's back to feeling fine shifting except into 1st.
I'd like to get as much life out of the current transmission as possible as I just don't have $4,000 to fix the transmission right now and they also wanted $2,000 to fix the 4x4 issues I'm having by replacing the transfer case. I work from home and don't drive the explorer more than a couple of times a week and to go camping.
Do you guys have recommendations for stuff I can do/fix myself? I was thinking of doing a transmission fluid flush as it's highly probably it has never been done but info for the manual M50D transmission is really hard to find.
It's my first time doing a transmission fluid change and I need some help. I put my vehicle info in Amazon and it's showing the manual is a 5-speed M50D, is that correct? All the videos I'm finding are for automatic transmissions where they pull the transmission pan to change the fluids and filter. I can't seem to find that on my xploder but I do suspect that is the drain plug in the first pic with the yellow paint on the right side of it, right? Does the manual transmission also take Mercon V (I've purchased 10 quarts already)? Does the manual have a filter I should swap and where can I get the gasket for the pan if it exists? What's the best way to replace the fluids and how do I measure when it's full? I don't have the tow package or trans cooler.
Thanks in advance,
Justin
Thanks in advance,
Justin
