Fixed Door Lock Problem | Ford Explorer Forums - Serious Explorations
RickToro
Woodridge, IL
98 xlt
DRIVERS DOOR LOCK DID NOT LOCK WITH THE DOOR SWITCH. DRIVERS DOOR WORKED FINE WITH REMOTE AND ALL OTHER SWITCHES WORKED FINE ALSO. REPLACED SWITCH DID NOT HELP. TOOK APART THE BLACK PLASTIC 'BARREL' BETWEEN DRIVERS DOOR AND BODY OF CAR. LOOSENED THE TOP BOLT (3/8?) AND REMOVED BARREL. HAD TO CUT THE RUBBER BOOT TO ACCESS THE WIRES. WHEN I DID, :us: I FOUND A PINK/BLU WIRE HAD BROKEN. THIS WIRE IS SO THIN I CAN'T BELIEVE FORD WOULD USE IT..OH WELL..I USED ELECTRICAL TIES TO BIND THE RUBBER BOOT BACK TOGETHER AND ALL IS WELL FOR NOW.
