bnz 41
- October 24, 2005
- NE
- 92 XLT
I just wanted to get some advise as to what to check next. First some background. My 92 xlt wouldn't go into 4X4 when I pressed the button. The light would go on but no power to front wheels and no clunk from transfer case. I could hear a click in the back (computer should be working right?) but nothing from the t-case.
Anyway, I printed off the excellent shift motor info off of this site and tore into it. Sure enough the plastic bushing was totally destroyed. I replaced it with a little urethane bushing I had at home (hopefully the right thickness- I just guesstimated). I put it back together and still nothing. So I took it back apart and cleaned the connections on the brushes and winding and also tried to make sure that there wasn't a piece of the old bushing holding something up. Unfortunately I didn't apply power when apart so I could be sure the motor is turning.
When I got it back together and pressed the button, the light still went on and again I heard a click but no clunk from the t-case. I thought I heard the motor click but it was hard to tell with the engine running. I tried low side just for giggles and sure enough clunk and definately low side gearing but it still didn't seem like any power to the front wheels. (I did some tight turns on both gravel and pavement and no shuddering).
I'm kind-of stumped. I don't know if its still a shift motor issue (by the way I forgot to say that I made a match mark and the cover is in the same place it was before) or if I have a hub problem or t-case issue. At this point I'm just grasping at straws so hopefully one of you might be able to help me out.
Thanks,
Bnz 41
Thanks,
Bnz 41
