Fixed starting problem 94 explorer limited | Ford Explorer - Ford Ranger Forums - Serious Explorations
tomhilbil
crystal lake , il
94 limited
Had problems with my 94 exolorer limited starting. she would turm but not fire. also on occasion she would die while driving. I changed the fuel filter, cleaned the idle air control valve and replaced the fuel pump relay but still the problem persisted. I took her to the garage and paid 300$ for a new fuel pump and she was good for a day and then same problem. Finally after reading countless similar problems posted to these forums i replaced the EEC relay and have not had any problems in 2 weeks. hope this helps some folks and best yet will save you $$$$
mgmgmg
Plymouth, MN
'94 LTD '10 LTD V8
joey77
lima ohio
98 ford ranger sport
MY problem was the crank sensor
I have a 94 explorer limited. after replacing the 4.0 engine.It started and ran like crap.After a few starts it would`nt start at all.Took it to garage and they replaced the crank sensor and repaired some burnt wires on drivers side that got against exhaust manifold cost $140 to fix runs great now. drove 150 miles. barely used 1/2 tank gas. great vehicle. check crank sensor. It operates injectors,timing,spark.
tomhilbil
crystal lake , il
94 limited
thanks for advice
so far 400 miles and no problems starting. i could use better miledge so i will keep the crank sensor on my priority list
