saxon
- March 30, 2006
- seattle, wa
- '91 & '93 EB, 4WD, 4-door
Where to start...?
While removed and installing a used but rebuilt A4LD in my 1991, I noticed oil collecting at the bottom of the V6 oil pan. Brown engine oil, not trans. fluid. I assumed that it was the rear main seal and so pulled the flywheel off the other night (putting a Sonnax crank spacer in, so needed to pull the flywheel regardless; see: http://www.explorerforum.com/forums/showthread.php?t=164540).
Was surprised to see that the seal looked great and that the oil appears to be coming from the "u" dip in the rear of the oil pan. I have photos I can email directly to anyone who wants to give out their email address. Was even more surprised to see that in the Haynes manual step one of replacement of the oil pan gasket is "remove engine." Way to go Ford! whatever.
A frugal thought occurred to me. I have no intention of ever pulling that engine unless I'm pulling it to replace it. If I cleaned the rear of the block and oil pan to surgical cleanliness, couldn't I JB Weld along the rear connection of the oil pan to the block to stop the leak? (or use some other surface sealant besides JB Weld?)
