Flashing 4WD high and low lights. | Ford Explorer Forums - Serious Explorations
Biguy984
98 Mercury Mountaineer
Hi I have a 98 Mercury Mountaineer. 192,000 miles. Had transmission work done. The truck was riding good. when flashing 4wd High and Low came on. It flashes about 6times. And my Engine Light stay's on. Plus my wheels want turn,keep hearing clinking noise. :( I took it back to the transmission people, and they told me that the transfer case went bad. OK!! so i got a second opinion, So I go to Dealership, they charged me $100 to put it on the diagnostic machine. and said my 4wd had locked up. and i needed to replace a module,sensors, And a speed sensor. And it would cost me 1,000 for repair's. :mad: Can anyone help me out, So i can do the repair's and save money PLZ!!
I'm having exactly the same problem with my 97 Explorer. 4x4 lights flash intermittently about 6 times at random times. Also getting the 'clunk' on corners as the 4x4 transfer case pops out of gear because I'm in 4x4 on dry road (switch in auto).
One thing I noticed was this - the car would only enter 4x4 and do the 'strain then clunk' thing after the car had been turned off then restarted. It happened to me a few times at the petrol station, for example. When I took it to the Ford garage, he immediately gave me the story about the TC clutches (black oil there, apparently) and also pointed out that we have non-identical tyres (same size of course but different brand/tread).
So what do you think ? If the tyres or TC gears were the problem, wouldn't the car be torquing up on all corners, not just after being switched off ? If I drive the car in a straight line after restart it seems to slip back into 2WD.....so it seems to me like a switching issue not a mechanical one. Shouldn't the car start in 2WD ?
My garage is also talking about replacing the TC etc.....but I suspect all it really needs is an electrical fix. Can anyone shine a light on this please ?
