Flashing Check Engine Light
Phildeez
elkland, Pennsylvania
2004 Explorer XLT
Yes, Flashing Check Engine Light and loss of power going up hill and at Cruising Speed on Interstate (70mph). Occasional engine stumble. If I release throttle then give more throttle than when stumble occurs operation continues as expected. My mechanics advice is to "Let it get worse, it will make the problem easier to find." Idles fine.
drdoom
VA
2005 Eddie Bauer 4.6L 4X4
What does the scan tool read?
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
2004 Explorer Owner’s Manual (Pages 10-11)
. If the light is blinking, engine misfire is occurring which could damage your catalytic converter. Drive in a moderate fashion (avoid heavy acceleration and deceleration) and have your vehicle serviced immediately.
Under engine misfire conditions, excessive exhaust temperatures could damage the catalytic converter, the fuel system, interior floor coverings or other vehicle components, possibly causing a fire.
http://www.fordservicecontent.com/Ford_Content/catalog/owner_guides/04expog3e.pdf
MrPulldown
Truckeee
2004, 4wd, 4.6l
Flashing check engine light means don't drive it is already worse.
Larryjb
2008 Ford Explorer
Have you checked all plugs, wires, coil packs? I'd start with plugs and wires.
Phildeez
2004 Explorer XLT
Yes I have replaced the spark plugs and at first that seemed to fix the issue. I plugged the diagnostic computer up to it and the only code stored was EVAP Leak... The last two times this issue has occurred that is stored by the computer. And I agree that it's already worse. But unfortunately I'm a working class man that barely scrapes by with a family. I cannot afford to pay somebody $80 an hour to find a needle in a haystack. Yet at the same time this car is literally my lifeline. No Car = Crash and Burn. So for now a friend of mine is going to check the fuel pressure.
Larryjb
2008 Ford Explorer
If you can, borrow a scantool to view live data when it starts to buck. You may find a pattern. If it's mostly on a few cylinders, you know it's something that can only affect those cylinders, e.g. plugs/coils/wires/injectors etc. If it's random across all cylinders, then you can look at other possible sources.
Phildeez
2004 Explorer XLT
Ok, so...Good news! I believe the issue is solved!. I replaced the Ignition Coil and Wires..BOOM! No more stumble. This weekend provided we don't get snowed in I'll test on highway. I'll update then. Thanks for the help.
Phildeez
2004 Explorer XLT
What are your thoughts on the BlueDriver device? Im close to getting 1. It's just 100$ is alot of cash to drop on something your unfamiliar with. I have spent hours reading about it. It can read abs and transmission codes aswell. Anyways that was the plan..Get read out when it happenes. But it is most likely fixed. Fingers crossed.
Larryjb
2008 Ford Explorer
I know nothing about the bluedriver Device. I got an OTC Genisys off Ebay. More expensive, but it can cycle the abs if necessary too.
TechGuru
Location
Texas
2003 XLS 4X4 4.0L FLEX
Larryjb
2008 Ford Explorer
I never looked into what Forscan can do for diagnostics because I got the Genisys about a year earlier, then got Forscan to turn the TPMS off on the Explorer.
Even though the Forscan can do all that, I'll still be using the Genisys for diagnostics because I'm familiar with it, and it's easier for me to set up. Forscan would have advantages because you would be able to print out results and graphs without having to purchase an additional and expensive print module for the Genisys.
R Lost power and check engine light flashing Stock 2002 - 2005 Explorers 2
C Check Engine Light flashing only when getting on the expressway Stock 2002 - 2005 Explorers 6
O check engine light on and flashing p303 and p316 Stock 2002 - 2005 Explorers 3
H Check Engine light flashing!!! Stock 2002 - 2005 Explorers 5
F 02 Explorer O/D flashing, Check engine light Stock 2002 - 2005 Explorers 7
R Check engine light and o/d light flashing code p0775 and p0456 Stock 2002 - 2005 Explorers 1
J OD light flashing..'check transmission' Stock 2002 - 2005 Explorers 6
S 2002 Expo cooling system boiling and OD OFF light flashing Stock 2002 - 2005 Explorers 11
R 2002 Explorer 4x4 4.0 , turn off OD for flashing OD light help? Stock 2002 - 2005 Explorers 4
S O/D Flashing, loss of forward gear after engine install Stock 2002 - 2005 Explorers 10
W Flashing Engine Light Stock 2002 - 2005 Explorers 12
J 02 EXPLORER 4X4 HIGH LIGHT FLASHING Stock 2002 - 2005 Explorers 2
S Headlights flashing while car is off Stock 2002 - 2005 Explorers 1
B 2003 Explorer with DTC P1780 & P0775 & O/D flashing. Stock 2002 - 2005 Explorers 23
W 03 xlt 4.0 4wd 5r55w code p0735 p0775 flashing OD HELLLLLLLP! Stock 2002 - 2005 Explorers 18
B flashing 4x4 high light Stock 2002 - 2005 Explorers 0
P Od light flashing hard shifting and diesel noise Stock 2002 - 2005 Explorers 2
P 04 explorer od off flashing won't drive Stock 2002 - 2005 Explorers 2
M ABS locked, Traction Control off and 4X4 high flashing? Stock 2002 - 2005 Explorers 2
J 2005 Ford Explorer XLT -- while driving the O/D light on the dash is steadily flashing Stock 2002 - 2005 Explorers 1
O please help 05 mountaineer no crank, security light flashing fast, had bad ground term Stock 2002 - 2005 Explorers 13
X 4x4 high and O/D light flashing Stock 2002 - 2005 Explorers 3
S 4x4 Light flashing and front binding 02 Explorer Stock 2002 - 2005 Explorers 5
F No ABS, RSC, or A4x4 - light flashing 8 times - Help! Stock 2002 - 2005 Explorers 2
E Abs light on and 4x4 high light flashing Stock 2002 - 2005 Explorers 4
S 2002 flashing 4x4 high and low lights 3 times Stock 2002 - 2005 Explorers 1
E 4x4 flashing but... Stock 2002 - 2005 Explorers 4
T 2002 ford explorer xlt shifts hard into 2nd gear and od light flashing Stock 2002 - 2005 Explorers 25
B Flashing O/D light flashing 4x4 light Stock 2002 - 2005 Explorers 0
M No Crank, No Start, Flashing Theft Light: SOLUTION Stock 2002 - 2005 Explorers 3
F Seat swap 2004 with 2002 explorer now air bag flashing light Stock 2002 - 2005 Explorers 2
K 02 MOUNTAINEER OD LIGHT FLASHING Stock 2002 - 2005 Explorers 1
C OD FLashing.... Stock 2002 - 2005 Explorers 23
S Head and tail lights flashing, truck off Stock 2002 - 2005 Explorers 4
H Red light flashing under the turn single Stock 2002 - 2005 Explorers 3
C 4x4 high flashing occasionally Stock 2002 - 2005 Explorers 4
J 4x4 high lighting flashing code p1827 Stock 2002 - 2005 Explorers 1
J 2004 Explorer (K) flashing O/D off light ABS light. Stock 2002 - 2005 Explorers 2
E 2004 Mountaineer O/D light flashing Stock 2002 - 2005 Explorers 3
R O/D light flashing and service engine light on Stock 2002 - 2005 Explorers 2
V 4X4 light flashing Stock 2002 - 2005 Explorers 4
K 2002 Airbag light flashing Stock 2002 - 2005 Explorers 3
G 2003 Explorer Sport O/D Light Flashing - After O/D Sprag Replacement Stock 2002 - 2005 Explorers 0
G Test drive: ABS light came on, flashing 4x4 high Stock 2002 - 2005 Explorers 7
I Intermittent "O/D OFF" flashing issue Stock 2002 - 2005 Explorers 1
B Wont Start, Theft Light Flashing Stock 2002 - 2005 Explorers 22
J Tranny Swap 4x4 High Flashing Stock 2002 - 2005 Explorers 7
R 2003 4.0 explorer flashing OD light. Stock 2002 - 2005 Explorers 9
B 4x4 high light flashing! Stock 2002 - 2005 Explorers 6
I 2003 Explorer 4x4 light flashing Stock 2002 - 2005 Explorers 1
Similar threads
