Flashing HID Lights (to warn on comers, etc)
jeffreycowart
Chattanooga, TN
2013 Explorer Limited 4WD
I doubt this is a question that can really be answered, but I thought I would throw it out and see if I can get some responses from owners that have had Ex's for a few years, or maybe others with HID lights.
From what I read cycling HID's is what "hurts" them the most. I think this is the reason on Limiteds with HID lights they turn on the Amber lights as DRL instead of the HID's.
I have a question if these two scenarios will impact the life of my factory HID's on my Explorer. (I had my 2007 Ex for 6 years and never changed a bulb).
1. Flashing (pulling back on the turn signal) during daytime for various reasons like letting someone know it is OK to pull out, let a trucker know he can come over, warn others of speed traps, etc. I typically give 2-3 pulls on my lights in these situations.
2. My garage is dark, so almost every time I get in my car and start it up, the auto lights turn on for about 30 seconds, until I pull out of the garage and it detects it is daylight. It also happens sometimes going under long underpasses, short tunnels, etc.
My wife has a 2007 Acura MDX with HID and the HID's turn on everytime the drivers door is opened and we have never had to replace a bulb in it. Not sure if Acura uses "higher quality" HID's.
I assume these Ford HID's were built for normal useage like flashing and short cycles from the auto headlight feature. Should I turn OFF the auto headlamp feature to extend the life, or will that only have a marginal affect on HID life?
Have a good weekend everyone.
Jeff
IAmTodd
4x Explorer Veteran
Johnstown, PA
2001 Jeep Cherokee
Everyday use like that won't hurt the bulbs. They're designed for that in mind and all the OEMs use quality bulbs. Over time you'll begin to notice the color start to fade and the lights start to dim. If you were to replace one of the bulbs in the MDX with a new factory one you'd definitely see the difference. That's why the recommend replacing them in pairs.
My Saab for the first four years of it's life had the HIDs on all the time. They're still burning strong.
Warrant
Layton UT
2000 Sport
Not sure how factory bulbs work so this all my be irrelevant but I've converted to HIDs in my 2000.
Im not able to flash my lights when they are off because the the brights work by physically moving the bulb with a magnet (it uses the brights circuit to power the magnet) That is a down side.
I think all HIDs need a large spike of power to "ignite" the bulb, this is why they flash brightly for a instant, and then go dim and slowly get brighter. I guess you could flip the switch several times if you needed to signal someone in the day time, but Ive found that they don't flash from the spike of power all the time.
I do have auto lights, but I keep them off for the reasons you described, no reason the lights need to be coming on and off like that, and if you cant remember to have your lights on when you need them, then you have a problem. I would say it does hurt life, but its within there design parameters.
Another thing, my truck will flash its lights when they lock key is pressed twice, the sprike of power makes them flash fine, but I cant imagine thats good for the bulbs, so I try not to do it alot.
I think the lights will last years and years under these normal uses, its hard to say when one goes out what the cause was though.
C Check Engine Flashing Stock 2011 - 2019 Ford Explorer Discussion 19
P People keep flashing their lights at me. Stock 2011 - 2019 Ford Explorer Discussion 21
G Replace 3ds Hid bulb of 2013 limited Stock 2011 - 2019 Ford Explorer Discussion 1
L 2014 OEM HID Headlights Stock 2011 - 2019 Ford Explorer Discussion 14
R Stock HID, did anyone replace them yet?! Stock 2011 - 2019 Ford Explorer Discussion 10
Q HID compared to Halogen Headlights Stock 2011 - 2019 Ford Explorer Discussion 3
S Ford Goes Cheap With Halogen Over HID On 2017 Stock 2011 - 2019 Ford Explorer Discussion 112
R HELP - Explorer 2015 OEM Limited HID headlights for 2014 Sport Stock 2011 - 2019 Ford Explorer Discussion 24
C HID Headlight HELP! Stock 2011 - 2019 Ford Explorer Discussion 21
B HID Headlights Stock 2011 - 2019 Ford Explorer Discussion 18
N 2011 - 2015 HID & 2016 LED Lumens and Kelvin? Stock 2011 - 2019 Ford Explorer Discussion 1
C HID retrofit for '11 Limited Stock 2011 - 2019 Ford Explorer Discussion 0
N Ford HID Kit worth getting from Ford parts? Stock 2011 - 2019 Ford Explorer Discussion 24
S Swap HID from 2015 Limited to 2015 Sport Stock 2011 - 2019 Ford Explorer Discussion 17
X Warning to whoever want to use Coolbulb as HID Stock 2011 - 2019 Ford Explorer Discussion 2
K Do HID equipped Limited's have HID Fog Lights? Stock 2011 - 2019 Ford Explorer Discussion 1
arttyszka 2014 Sport Headlights, HID or not? Stock 2011 - 2019 Ford Explorer Discussion 13
L Please recomend 4-5000k bi HID Stock 2011 - 2019 Ford Explorer Discussion 3
J 2013 Ford Explorer Sport HID mod Stock 2011 - 2019 Ford Explorer Discussion 17
W HID head light Stock 2011 - 2019 Ford Explorer Discussion 24
J Help to choose HID for my explorer Stock 2011 - 2019 Ford Explorer Discussion 14
K Why no HID's? 2013 explorer sport Stock 2011 - 2019 Ford Explorer Discussion 2
H 2011 HID's vs 2013 HID's Stock 2011 - 2019 Ford Explorer Discussion 3
G HID light cleaning Stock 2011 - 2019 Ford Explorer Discussion 18
K Which HID kit to buy? Stock 2011 - 2019 Ford Explorer Discussion 8
J HID Headlights Stock 2011 - 2019 Ford Explorer Discussion 10
T HID type and cost Stock 2011 - 2019 Ford Explorer Discussion 19
Y HID replacements for Foglamps? Stock 2011 - 2019 Ford Explorer Discussion 37
M HID's Stock 2011 - 2019 Ford Explorer Discussion 4
C non HID headlite brightness Stock 2011 - 2019 Ford Explorer Discussion 1
E Aftermarket lights Stock 2011 - 2019 Ford Explorer Discussion 2
S Reverse Lights Fuse Stock 2011 - 2019 Ford Explorer Discussion 8
MrWickd Interior lights/puddle lights won't turn on Stock 2011 - 2019 Ford Explorer Discussion 2
M Hazard lights and door open error went haywire while driving Stock 2011 - 2019 Ford Explorer Discussion 6
V 2016 Base, no marker lights? Stock 2011 - 2019 Ford Explorer Discussion 14
T Wiring fog lights to always ON? Stock 2011 - 2019 Ford Explorer Discussion 5
J Disabling interior lights in 2016 Explorer XLT? Stock 2011 - 2019 Ford Explorer Discussion 7
O Fog lights stay on...even with key out Stock 2011 - 2019 Ford Explorer Discussion 17
L 2018 fog lights Stock 2011 - 2019 Ford Explorer Discussion 3
R 2012 explorer interior lights Stock 2011 - 2019 Ford Explorer Discussion 1
N Cornering Lights? Stock 2011 - 2019 Ford Explorer Discussion 11
Q Differences Canada/US — Auto Lights Stock 2011 - 2019 Ford Explorer Discussion 29
Q BCM Programming - Trailer Lights Stock 2011 - 2019 Ford Explorer Discussion 23
L Trouble removing map lights Stock 2011 - 2019 Ford Explorer Discussion 0
D 2018 Explorer Puddle lights Stock 2011 - 2019 Ford Explorer Discussion 24
W ABS, traction management, brake lights on after battery replacement Stock 2011 - 2019 Ford Explorer Discussion 13
R How can I prevent cabin lights from turning on every time I turn off engine? Stock 2011 - 2019 Ford Explorer Discussion 2
Gilbert M Vega Can Signature Lights be Brightened? Stock 2011 - 2019 Ford Explorer Discussion 28
L My brake lights are stuck on, sorta Stock 2011 - 2019 Ford Explorer Discussion 10
C Adding emergency lights to explorer sport Stock 2011 - 2019 Ford Explorer Discussion 11
Similar threads
