Cobraguy
- February 22, 2008
- Phoenix...Greatest City on Earth
- 1995 EB & 1999 EB 5.0
There has been a lot of discussion about what electric fan will fit a 2nd gen 5.0 with the thick core radiator. Somewhere around 2000 or 2001, Ford put a thinner core, more efficient radiator in the 5.0 that allows a lot more clearance. But for the most of us, you only get 3.5" of clearance between the water pump shaft and the radiator. That severely limits your choices of fans if you want to incorporate a shroud too. There are a few double fan configurations that fit, but I wanted to avoid that if possible due to the incredibly high amp draw those can require when both fans are at full song (50 to 60 amps). Since I live in Phoenix, and the a/c goes on sometime next month and doesn't get turned off until November, the fans would be running at that heavy amp draw all the time. That would require a pretty serious upgrade to the charging system IMO. So, without resorting to a custom made shroud and fan (which is possible) I ordered in a Flex-a-lite 188 fan. This is a 180 fan without the controller and wiring since I wouldn't be using theirs anyway and it's about $60 cheaper that way.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=FLX-188&N=700+115&autoview=sku
Even though this shroud/fan assy doesn't cover the radiator perfectly, it's not bad. Plus, I know it will fit on my 95 with a V6, so it wasn't money wasted if it doesn't fit the 5.0. One last thing before I start...Derale says they have an electric fan/shroud being developed specifically for the Explorer they want to have out by SEMA. So while that is a ways away, it's possible a really nice fitting unit is on the way.
First, remove the clutch/fan assy and shroud using the appropriate fan tool. Then I removed the fan blade from the electric fan to make it easier to work with. Then I partially installed the fan. You can see the problem:
The fan blade itself however, has a depression in it that allows for the water pump shaft to protrude about a quarter of an inch into the fan. You will see that in a later picture. You can also shim the fan motor back about an eighth to a quarter of an inch if necessary without getting it into the radiator. I didn't need to do that, so I left that alone. After measuring and observing, I decided it looked like I could make it fit and went ahead and mounted the fan. For our application, it will actually mount 90 degrees from it's intended orientation. I went to my local Ace Hardware and picked up a bunch of nylon spacers and other miscellaneous hardware I thought I could use. The fan comes with some nice aluminum brackets that have plastic coverings on them to protect the nice finish during shipping and installation. I used spacers on top and bottom to position the fan vertically where I wanted it. Here you can see a couple of the spacers I started with. I actually ended up with much narrower spacers...quarter inch I believe. But this gives you the idea.
Please note that the bottom of the shroud is identical to the top. It ended up with the exact same spacers, height, etc as the top to place the fan exactly where I wanted it.
With the fan now mounted where I wanted it, I pulled it out, installed the blade back on the fan and reinstalled it. No joy. The clip they use to hold the fan blade to the shaft was too big and hit the water pump shaft when the fan turned. So I either had to come up with another clip, or move the fan away from the water pump shaft a bit more. I really was happy with the mounting of the fan, so off came the blade to find a new way to hold the blade. I dug through my supply of E-clips, fasteners. and other assorted fastening hardware trying to find something that would work. Due to the flat side of the fan motor shaft, I was limited with what would work. An E-clip was perfect, but if it rotated, the flat side of the shaft could allow it to come off. Not good. So I decided on drilling the shaft and using a small hitch pin. I covered the motor with duct tape to keep metal filings out and drilled a small hole through the shaft for the pin. Use a good quality bit and some WD-40 as cutting oil. Go slow...the shaft is hard. When done, you will have this:
Please note you can now see the "depression" in the fan blade I was discussing earlier. See how there is a bit of room for the water pump shaft to sit in. With the smaller retention clip, I no longer have a problem hitting the water pump shaft. I also believe this clip is every bit...if not more...as secure as the clip that came with the fan.
Prior to installing the fan assy, you will need to provide a means of pulling the wires outside the shroud. Here you can see the grommet I installed. There is actually a place on the shroud you can drill for this:
That pretty well has the fan installed and ready for wiring and programming. Please also note that while the picture above shows the fan shaft above the water pump shaft, I actually installed the fan assy so the fan shaft was BELOW the water pump shaft. I didn't want the engine to torque over and hit the fan shaft. This way, that cannot happen.
