kleake
- December 14, 2017
- Tulsa, OK
- 2011 Explorer Limited
There is a known issue with the actuators on these, and no, i have not swapped mine, but i'm not convinced that is the issue. I get defrost or front vent heat, but when I switch to floor, it switches, but there is little/no air flowing out. Nothing coming out the dash, nothing in the defrost, and I can only feel warmth at the floor vents, but no real airflow. This is a Limited with dual zone and it's the same on both sides. Is this an actuator that just isn't moving far enough or? If the actuator failed, I would think there would not be any movement at all and it would be stuck in one position only.
