shadowless127
- December 13, 2007
- Long Island, NY
- '01 EB AWD 5.0
Weird problem I've been having for the past 5-6 weeks. I've always had a slight coolant leak since I got the car but it was never a big deal. Cut to like a week before Christmas and I notice my temp gauge is higher then usual. Hook up my scanner and see that the temp is 214. So I see that my coolant level is low, so I top if off, problem goes away, kind of. The temperature now fluctuates (confirmed by gauge and OBDII scanner) intermittently. It will stay normal, then drop down to under 190, then creep back up. Sometimes It will be at normal temp, i'll stop at a light then when i take off from the light the temp plummets and the gauge drops all the way to the bottom line and then slowly creeps back up. It's done this a few times while underway as well.
Temp never goes above 214, which I know is not technically overheating, but considering I don't have an LS engine in this, I'd like it to stay under 200 lol
I also seem to be losing more coolant then I previously had, but I can't find a puddle and it's not coming out of my tailpipe or going into my oil.
I've noticed zero difference in performance or how it runs.
I'm guessing my first steps should be new radiator cap and a coolant system flush?
