cogs
- May 21, 2008
- texas
- '94 sport 2wd
[solved] fluid in vacuum lines/engine hiccups
this is a 'point me in the right direction' question:
just changed my transmission module (if interested in pictures, here's the link):
http://www.explorerforum.com/forums//showthread.php?p=2352120
there's fluid in the vacuum lines, and my engine is having troubles:
when driving or idling, the exhaust seems to be regularly pushing out more pressure, then going back to normal. i can tell it starts at the engine, cause the engine hiccups, and then i can tell it's going out the tailpipe simultaneously. it's like my engine has the hiccups, cause it's now and then. i think it's probably cause of the fluid in the lines, but i'd like to know what line to change first, to see if it'll at least clear that up. then, i know i'll have work to do changing out the other lines, etc. any advice about the vacuum lines, or the hiccup?
