Fluttering Noise from Driver's Side | Ford Explorer Forums - Serious Explorations
Ea0776
Saline, MI
2017 Ford Explorer XLT
Hi! I own a 2017 Ford Explorer and as of a couple weeks ago I now have this fluttering noise on the driver's side when the car is in motion. I've attached a picture of where I think the noise is coming from. I've adjusted the seat belt, confirmed all trim is intact, and the window seems to seal just fine. I cannot seem to figure out what this noise is. I suspect it may be coming from behind the column where I circled in the picture. Anyone else experience anything like this? If so, what was your fix?
Welcome to the Forum. :wave:
Do you have the Securicode panel? If yes, have you checked to make sure it isn't loose?
I do. I just check and the panel on the outside of the door does not appear to be loose.
There is a part inside that panel that guides the seatbelt to angle/move around freely. I never seen them flutter but mine was wedged after removing that trim to fix the moon roof and seatbelt didn't wanna move.
