wyochimneysweep
- August 13, 2007
- fargo, nd
- 97 explorer AWD 5.0
How about adding hub to unlock the front axle and driveshaft?
I just got back to the computer, sent her a PM about the t-case.
So unfortunately the 4.6L front drive shaft I picked up yesterday still does not fit (just barely tho). There's about 1/2 inch difference with the slip shaft all the way compressed.
The 4.6L shaft is 34 & 5/8" from the end of the u-joint to the end of the flange. There is 34" between my diff yoke and the t-case flange. The 5.4L shaft is a good 4" longer.
I'm wondering if it has something to do with my transmission. Do Eddie's have a different tranny? Because I had plenty of space between the t-case and the gas tank bracket and now the front driveshaft is too long. So for now you guys can ignore what I said about in needing to come from a 4.6L Just measure the distance before you go get a shaft.
I guess I'll just get this one cut down to size and suck up the cost. I'm tired of not being able to drive with 4 powered wheels.
Wow, I have been living in a cave. Sorry it's taken me so long to reply. I love the 4406 it's working great. It's been over a year now, and about 3 major wheeling trips and it's still solid as can be.How's the BW4406 working out now Jeff?
Yes, I have researched the drive shafts several times on here. This thread has the best final details for them, your's was the original. My rear shaft is 36" from rear flange to front u-joint. Night,
Hey...I was reading on a thread where this swap may not work with the secondary cats. Is that true? If it is, I'm dead in the water. I'll never get past the inspection.
