Flywheel shim when replacing clutch?
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
Getting ready to order a new clutch and related parts on rockauto and saw these shims listed.
This will be the second clutch I put into my Ranger, the first time was about 12 years ago. I did get the flywheel resurfaced at the time.
Does a shim compensate for resurfacing?
If so, I have no idea how much material was removed. I did not put a shim on last time, I did not know of them.
Should I put one on this time? I’m most likely going to resurface the flywheel again.
There’s many different thicknesses listed.
Can anyone clarify all this for me?
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
No shim needed IMO
Resurface flywheel is a good idea, however depending on its condition, usually some sandpaper or scotch brite and brake cleaner will do the trick.
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
Do you think that’s what they are for though, to make up the difference in lost metal?
Do you feel the clutch movement can compensate for the fractions of metal lost in resurfacing one or two times?
Maybe I’m not clear on what a shop does when they resurface a flywheel. I assumed they milled it down a little. No?
ptf18
2002 Sport Trac
Had a clutch job done on my "88 Cherokee many years ago. The flywheel was "surfaced" and the finished job exhibited a heck of a lot of freeplay. Thing is with a hydraulic system there is no way to reduce the freeplay.
20/20 hindsight I should of insisted that what ever they removed from the flywheel surface, a shim should of have been added to the crankshaft to flywheel joint.
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
Dang that stinks!!
Shim is not going to hurt anything here
ZJust so @RangerX knows I have done about 20 of these clutches, usually surface the flywheel never used a shim and I am always able to get full clutch action. I guess it depends on the flywheel thickness, how many times has the flywheel been surfaced? Usually they go two clutches then the truck gets crushed or the flywheel gets replaced.
ptf18
2002 Sport Trac
410.... Just to be clear. I had full clutch action as you post BUT....the amount of freeplay (before you could feel the throw-out bearing contacting "stuff") was "excessive" (to me). No way to adjust that freeplay out.
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
copy that
The pedal feel I get it......hard to adjust with hydraulics
I have put shims (washers) behind the slave cylinder before to push it forward 1/4" or so.........worked wonders on that truck. I guess I could have shimmed the flywheel too...........
good discussion!!
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL Pumpkin Edition
Callsign
AB7FH
I would put a .025 shim in there just to be safe. I always use a new flywheel when replacing the clutches in my vehicles. Expensive yes, but it brings on piece of mind that everything is back to spec and should last as long as original.
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
Typically a flywheel is ground on a surface grinder. Grinding is a slow process that is tedious. Typically you grind just enough to return any discolored spots, and ensure the disc isn’t polished. Not much will have been removed.
The clutch shims tended to be used on mechanical clutches on older vehicles. You would sometimes get into a situation where the clutch didn’t want to release quite right. The hydraulics should be able to take up what they ground off.
It’s up to you, really. It should work just fine without it. But, an extra 25 thousands in there won’t hurt anything.
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
Good info and opinions all around! Thinking I’ll order the .025 shim, because why not, it’s under $5! Lots of time before the parts get to me, I can decide then whether to use it or not.
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
If I have a shim sitting around and had my flywheel surfaced I would run the shim
Under $5 with $800 shipping to HI right? LOL
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
Haha, yeah! But I figure since I’m already getting a clutch kit and slave sent, just slip that slim in the box!
Rockauto gives three shipping choices, UPS, FedEx, and DHL. The first two quote at about $100, DHL shows $49.
I ve never used them for anything ever, but for half the price I’d like to. Anybody have a reason not to? Would they take twice as long or something?
Mbrooks420
High Voltage.
EF Vendor
DHL isn’t the speediest. They also hand of to USPS often.
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
yes they are reliable and same speed as usps
I often get things DHL (because we order so much shi$)
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
Okay, maybe I’ll try them. Seems like it will probably take a hella long time nowadays regardless.
D 1994 Flywheel issues Transmissions & Transfer Cases 5
A flywheel wont turn after installing new tranny on 95 explorer 4x4 4.0 Transmissions & Transfer Cases 7
S Flywheel to TC issues Transmissions & Transfer Cases 7
H New Flywheel But... Transmissions & Transfer Cases 1
R flywheel problems i think Transmissions & Transfer Cases 3
F 97 4.0 flywheel Transmissions & Transfer Cases 3
L How did you move the flywheel to tighten all torque converter bolts? Transmissions & Transfer Cases 5
L 2001 Sport, Torque Converter stuck to flywheel Transmissions & Transfer Cases 9
T flywheel r&r Transmissions & Transfer Cases 1
K Flywheel spacer - do I need it? Transmissions & Transfer Cases 3
N Any ford flywheel/clutch gurus? Transmissions & Transfer Cases 1
KPT Idiot repair shops and flywheel bolts Transmissions & Transfer Cases 1
9 Easy one: Flywheel alignment on crank? '93 4.0/5-spd Transmissions & Transfer Cases 5
B Flywheel spacer removal. Transmissions & Transfer Cases 7
R pressure plate on the flywheel problem Transmissions & Transfer Cases 3
K flywheel problem Transmissions & Transfer Cases 20
D flywheel bolts Transmissions & Transfer Cases 7
L Torque settings for auto and torque convertor to flywheel Transmissions & Transfer Cases 3
G flywheel/crankshaft not turning Transmissions & Transfer Cases 22
E Antifreeze Leak behind Flywheel Transmissions & Transfer Cases 1
C A4LD torque converter to flywheel - hatch ??? Transmissions & Transfer Cases 3
J flywheel Transmissions & Transfer Cases 9
P Can I change the flywheel while parked on an incline? Transmissions & Transfer Cases 6
B Replacing Flywheel Transmissions & Transfer Cases 22
C dana 35 4.10 shim ??? Transmissions & Transfer Cases 1
9 Rear Differential: Bearing/Shim/Spacer Spider Gear Transmissions & Transfer Cases 15
Burns Camber Shim For D44.....Someone Help Me!!! Transmissions & Transfer Cases 9
J 2003 Explorer Transmission Problem AFTER replacing solenoid Transmissions & Transfer Cases 1
B replacing atf cooler hoses Transmissions & Transfer Cases 0
V Replacing lock-up & 3/4 solenoids Transmissions & Transfer Cases 1
A Replacing 5r55w transmission, pointers? Transmissions & Transfer Cases 1
R Replacing my 97 5r55e, NEED HELP! Transmissions & Transfer Cases 0
F replacing lower oil pan gasket on 97 explorer Transmissions & Transfer Cases 3
M no 4th gear after replacing I/M and O/D servos Transmissions & Transfer Cases 7
R Still have P0741 after replacing TCC solenoid Transmissions & Transfer Cases 9
Lesterclan What to replace while Im replacing the torque converter Transmissions & Transfer Cases 7
M replacing trans in a 1999 explorer Transmissions & Transfer Cases 6
H Shift motor replacement - Removing/Replacing the Brown Wire Transmissions & Transfer Cases 3
C Replacing Transmission Cooling Lines Transmissions & Transfer Cases 13
E 2002 Explorer. My 5R55W lost all gears after replacing the solenoid block & fluid. Transmissions & Transfer Cases 13
G Has anyone replacing there auto tranny had any experience with these guys? Transmissions & Transfer Cases 7
D Wanted information on replacing the slave cylinder. Transmissions & Transfer Cases 2
G Can't shift out of neutral after replacing transmission Transmissions & Transfer Cases 7
B Help for Replacing Input Shaft Bearing Transmissions & Transfer Cases 1
M Replacing A4LD in 91, need some help. Transmissions & Transfer Cases 21
9 I need help replacing the range sensor. Transmissions & Transfer Cases 1
4 Replacing transfer case Transmissions & Transfer Cases 25
D Replacing the Viscous Coupling in a 4410 Transmissions & Transfer Cases 9
F Debating on replacing trans Transmissions & Transfer Cases 1
C Replacing Bell Housing Bushing. New Torque Converter also? Transmissions & Transfer Cases 7
Similar threads
