Do the fog lights on 1997 explorer have an adjustment screw? How do you adjust the height?
there should be a height adjustment screw in the center of the bottom of the light where it attaches to the mounting bracket. access from the rear. i haven't looked at an Explorer, but i happen to know that's how the Mountaineer fog light works. it's a good bet the Expl works the same way.
There is a small amount of addjustment, a 14mm nut IIRC. Soak it ahead of time if you have any rust. Also check the bracket, they do get bent sometimes, which throws it off a good bit.
