Fog Lights on Base Pre 2016 Model
lowqjr
South Texas
2013 Explorer
Check out my fog lights
I have a 2013 explorer base and wanted some fog lights. Dealer price for fog lights was $125 x 2 and $60 just to mount them with no wiring. I said screw that, I went to Wal-Mart and purchased some $20 fog lights and mounted them myself with some homemade brackets. All I need is the wiring which I will do this week. Tell me what you think.
Before:
http://i235.photobucket.com/albums/ee106/lowqjr/My Explorer/truck2.jpg
http://i235.photobucket.com/albums/ee106/lowqjr/My Explorer/truck3.jpg
After:
http://i235.photobucket.com/albums/ee106/lowqjr/My Explorer/truck4.jpg
http://i235.photobucket.com/albums/ee106/lowqjr/My Explorer/truck5.jpg
http://i235.photobucket.com/albums/ee106/lowqjr/My Explorer/truck1.jpg
Lights:
http://i235.photobucket.com/albums/ee106/lowqjr/My Explorer/trucklights.jpg
Join the Elite Explorers for $20.
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
NAYDAMO
2011 FORD EXPLORER XLT
Very nice...
ssilence
2012 Ford Explorer
This is a mod that I am definitely wanting to do. Any chance that you can show us the bracket you made? Or have a step by step (i.e. how did you cut the hole, wiring diagram for hookup, etc..).
harlenm
Shelton, CT
2013 Limited(lemon swap)
Probably work better than the OEM fog lights too!
Spengracin
Fairfield, Ca
2012 AWD Limited
Looks great, some install detail DIY for others would be great, thank you for sharing.
JETZ
2012 Explorer Limited
When you use the 'IMG' code the pics load, and no clicking req! ;)
Good mod, want to change mine over to HID also!
Before:
After:
Lights:
VinceL
Frisco, TX
2013 Explorer Limited
Here you go!
Before:
After:
Lights:
lowqjr
South Texas
2013 Explorer
I will post some more pics once I finish wiring.
Razziel24
Guayaquil
Explorer 2012 3.5 V6 Base
Nice job congrats, im about to do the same, the only thing I did order from Ford, was the XLT light switch with the button for the fogs, I want it to look stock from the inside.
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
Very nice, looks OEM.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve II
Callsign
VE3
That answer would likely be NO and YES. The NO would be for the intended use of the OEM's as FOG lights. The installed ones are Driving lights and as such would likely be ineffective in fog or similar conditions. I don't see why some drivers use the fog lights in normal night driving along with their headlights. I'm glad that some jursidictions have made that illegal. As I have posted in other threads, this is just a form of light pollution hindering the ability of oncoming traffic to see properly, especially if they are not adjusted properly.
That being said, they certainly do add to the appearance of the base model in a very positive way. Nice job lowqjr.
Something to keep in mind if these are classified as fog lights. From what I've read, in Texas, fog lights must be aimed so that the driver's side light projected beam is no higher that 4" below the center of the lamp at 25 feet. If I were to use my Limited as an example that would mean that the beam at 25 feet cannot be higher that 12" off the ground. The center of my fog lamp is 16".
JETZ
True fogs are yellow.
Our 'fog' lights might as well be DLR's, too weak for any serious illumination.
Gole8935
Florida
2012 & 1999 Ford Explorer
How did you mount them? Looks good! Did you have to take the bumper off?
Thanks
John
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
Any chance we could see a photo of the mounting brackets you made?
Gole8935
Florida
2013 Ford Explorer Fog Lights
How did you cut out the plastic covers for fog light installation?
mysupratoy94
Southern California
2012 Explorer(Base Model)
Same question here... thats a perfect cut. Some close up shots of the fitting of the light would be great!
Alan in AZ
Phoenix AZ
2013 Limited 4WD
True fogs are yellow...
No - some are - but most real foglights are plain old white lights. Either works fine.
Fogs need to have a distinct vertical light cut off and a very wide beam. It is the beam pattern that is important not the color.
Driving lights are not fog lights. Driving lights are usually supplemental high beams, however they can also be supplemental low beams - the difference is critical - you should not have supplemental high beams active except in high beam mode...
These are probably mounted too low to be effective as long throw low beams anyway... True fogs would have been a better choice - esp as DRL's
If you wire these as the stock fogs are wired and they are aux high beams (and from the packaging I think they are) you will have them on at the wrong times and will be blinding those driving towards you.
Alan
lowqjr
South Texas
2013 Explorer
For all those wondering how i cut out the plastic for the fog lights, I used a kitchen knife and one of those single razor blades. It looks perfect but its not. I'll take pics of the plastics cut outs.
lowqjr
South Texas
2013 Explorer
